Krown rustproofing
Old Sep 22, 2020 | 06:29 AM
Rennz's Avatar
Rennz
Default Krown rustproofing
Just picked up 06 is350 with 51000km, pretty mint. I live in Toronto and the car will be outside most of the time. Does anyone recommend krown rustproofing or should I just not get rustproofing done at all?
Old Sep 22, 2020 | 07:16 AM
Aspect's Avatar
Aspect
I'd say rust proofing is better than no rust proofing. I've only used Krown so far(not out of bias) and it's alright
Old Sep 23, 2020 | 06:50 PM
winterturb's Avatar
winterturb
Yes. I live in Alberta where we get salt and gravel but not to the extent you don in Ontario and Quebec. A good friend in Ontario uses chain saw oil every fall. It’s sticky and gooey and really sticks And his 12 year vehicle and 12 year old vehicle have no bone zero rust anywhere in the undercarriage. It cost about $12. Get a paint sprayer and spray the underside with chainsaw chain oil and you Won’t have rust. And it’s easy to clean off if you need to. And you can do it.
Old Sep 23, 2020 | 07:10 PM
Krown rustproofing to be blunt, sucks. The stuff simply doesn't last that long find a shop to treat with Fluid Film (or do it yourself) it is far better. Fluid Film will soften or even remove spray on rubber type undercoatings (not any factory coating), which is not a bad thing.
Chain oil will destroy rubber bushings.
Old Sep 24, 2020 | 07:33 AM
winterturb's Avatar
winterturb
Originally Posted by Lexus2000
Krown rustop
Thanks for the information and correction! Take heed op!
sdmfbrando
Jun 8, 2020 12:05 PM
jst17
Jun 19, 2014 01:33 PM
JerryX
Jul 14, 2011 12:08 PM
flipside909
Jun 15, 2006 11:34 PM
