Check completed
Old Aug 7, 2020 | 09:15 PM
BRP99's Avatar
BRP99
Default Check completed
Hey y’all new to Lexus here just bought my 2008 is350(amazing car) was wondering if it’s normal on every start up for it to say check completed with the red warning light. Thanks
Old Aug 8, 2020 | 12:42 AM
AMIRZA786's Avatar
AMIRZA786
I have a 2010 IS350, and the "Check Completed" is normal, but it shows up in an LCD display but goes away quickly. No red warning lights on mine unless I step out of the car with my keyless remote in my pocket
Old Aug 8, 2020 | 05:22 AM
MikeFig82's Avatar
MikeFig82
https://drivers.lexus.com/lexusdrive...etails/ART2645
Old Aug 8, 2020 | 11:55 AM
BRP99's Avatar
BRP99
yeah mine displays on the LCD Display too with the red warning light symbol ⚠️ But does go away quickly
Old Aug 8, 2020 | 12:22 PM
AMIRZA786's Avatar
AMIRZA786
Then you are fine. You would only need to worry if the warning light does not go away. The link @MikeFig82 posted should guide you on what the warning lights are and if they need attention
Old Aug 8, 2020 | 12:23 PM
BRP99's Avatar
BRP99
sweet man thank you
Old Aug 8, 2020 | 12:38 PM
MikeFig82's Avatar
MikeFig82
sweet man thank you
The red triangle will illuminate when its nearing your oil change interval. You'll notice it will stay on longer for a few seconds. Once it's at 5k miles is will be on constantly until you reset it. Another it will illuminate if you have AWD and problems arise. The triangle color will vary in the situation for it was triggered.
Old Aug 10, 2020 | 08:33 AM
Bichon's Avatar
Bichon
Can you elaborate? My master warning triangle has come on for a host of issues including maintenance interval, low washer fluid, low tire pressure, ice buildup on the park assist sensors, check vsc, even a door or trunk open, and I've never seen any color other than red.
Old Aug 10, 2020 | 09:16 AM
MikeFig82's Avatar
MikeFig82
It doesn't pertaining to the 2nd Gen IS. I think the 3IS has the master light in yellow also maybe the LS series.
I should've been more clear. Master light in red, or yellow.
LEXSOOS
Dec 11, 2006 07:18 AM
GS300Rich
May 22, 2005 08:20 PM
SCWells72
May 6, 2003 07:59 AM
nolimit94t
General Classifieds
Feb 19, 2003 05:50 PM
