Could use some help [Spark plug replacement]
Old May 19, 2020 | 05:55 PM
Bumburglar's Avatar
Bumburglar
Default Could use some help [Spark plug replacement]
Hey everyone! (All usernames I wanted were taken so I chose this out of frustration/humor so dont judge me lol)
I'm new to this ClubLexus thing and somewhat new to cars. Ive done my oil change, replaced front rotors and brake pads, and swapped out my stock intake for a short ram and a couple other small things. So I'm not a complete newbie but I still am learning.
So I was thinking of replacing my spark plugs but it seems really complicated and out of fear of ****ing something up on my engine or the spark plugs themselves I've called around for estimates and some places have told me I'm also going to need an intake manifold gasket? And spark plug boots? Does this sound right to anyone? I'd really appreciate so informative advice. Thanks in advance!
Edit: I have a 2008 is250 RWD
Old May 19, 2020 | 06:00 PM
MikeFig82's Avatar
MikeFig82
https://www.clublexus.com/forums/is-...ug-change.html
Old May 19, 2020 | 06:52 PM
primavera's Avatar
primavera
Old May 19, 2020 | 10:07 PM
primavera's Avatar
primavera
https://www.clublexus.com/forums/is-...necessity.html
Old May 20, 2020 | 06:51 PM
Bumburglar's Avatar
Bumburglar
Seems easy enough, but I do not have a torque wrench and I dont understand what it means to apply a certain amount of torque when screwing in my new spark plugs 🥴
Old May 20, 2020 | 07:26 PM
primavera's Avatar
primavera
I believe it’s 18 ft-lb of torque for spark plugs
Old May 21, 2020 | 11:59 AM
J2FUEGO's Avatar
J2FUEGO
@Bumburglar You might be able to borrow one from your local Auto Parts Store, such as an Autozone, which has a lend a tool program. If not call, call around. If you can't find one, just make the investment in buying one, so you have for the next project you work on.
Here are some links to some on amazon that others have recommended for under $100:
( I personally would buy brand names that are known for their quality in their tools but in case you are in a pinch with all that is going on in the world, here these are)
https://www.amazon.com/TEKTON-Torque-10-150-Lb-13-6-203-5-24335/dp/B00C5ZL0RU/ref=zg_bs_559968_1?_encoding=UTF8&psc=1&refRID=RK0SSD27Z3RCH52SZWDS https://www.amazon.com/TEKTON-Torque-10-150-Lb-13-6-203-5-24335/dp/B00C5ZL0RU/ref=zg_bs_559968_1?_encoding=UTF8&psc=1&refRID=RK0SSD27Z3RCH52SZWDS
https://www.amazon.com/TEKTON-24330-8-Inch-ft-lb-13-6-108-5/dp/B00FMPKAD0/ref=zg_bs_559968_6?_encoding=UTF8&psc=1&refRID=RK0SSD27Z3RCH52SZWDS https://www.amazon.com/TEKTON-24330-8-Inch-ft-lb-13-6-108-5/dp/B00FMPKAD0/ref=zg_bs_559968_6?_encoding=UTF8&psc=1&refRID=RK0SSD27Z3RCH52SZWDS
https://www.amazon.com/TEKTON-24340-2-Inch-ft-lb-33-9-338-9/dp/B00C5ZL1NS/ref=zg_bs_559968_8?_encoding=UTF8&psc=1&refRID=RK0SSD27Z3RCH52SZWDS https://www.amazon.com/TEKTON-24340-2-Inch-ft-lb-33-9-338-9/dp/B00C5ZL1NS/ref=zg_bs_559968_8?_encoding=UTF8&psc=1&refRID=RK0SSD27Z3RCH52SZWDS
And here is a link to a youtube video on how to use a torque wrench:
I hope this helps. I not quite sure what size torque wrench you need but I'm sure someone else will chime in & help you out.
Old May 22, 2020 | 06:59 PM
Bumburglar's Avatar
Bumburglar
J2FUEGO I appreciate the help buddy. I decided to just take the car to an experienced mechanic for the spark plugs because I myself am still kinda new to working on cars. Would rather pay 240 for the job now rather than 240+ if I mess something up.
IS2Fuego
Aug 27, 2018 10:43 AM
pcgs3
Jul 7, 2015 08:38 AM
ohno
Sep 3, 2009 08:38 PM
flipinsayi
GS - 1st Gen (1993-1997)
Jun 16, 2009 10:53 PM
desantura
RX - 1st Gen (1999-2003)
Jul 15, 2008 01:44 PM
