IS350 Fuel Injector Replacement DIY?
I’ve searched for about the last hour and couldn’t find anything. Getting P0302 and want to replace the #2 injector. Can someone point me in the right direction?
thanks!
thanks!
my 2007 is250 started miss firing on cylinder 4. Missfire starts about 25-30 mins after car has warmed up and and higher speeds. It goes away after i restart the car and idles fine but when i get up to speed of 80kmph + it comes back. I changed the coil today and will go on a test drive tomorrow. No issues with spark plug.
With regards to the high pressure injectors:
https://static.nhtsa.gov/odi/rcl/200...9V020-5505.pdf
...the removal & installation of those is quite involved, however... an SST for the seals + all the seals/dampers/o-rings-etc...
