Problem with door latch cable
Old Jun 22, 2019 | 11:21 PM
Rey06is250's Avatar
Rey06is250
Default Problem with door latch cable
Hello I have a 2006 AWD IS250 so it turns out my driver door wasn’t opening from the inside. It only opens from the outside. So then I took the door panel off and checked and found out that the cable was off and the top ball piece is broken. What should I do? Is this a major issue or I should just order the piece online and connect it. Windows work and lock works from the inside. I’ve attached a photo for a better understanding.
The first picture is the driver side latch
This is the driver side latch that connects to the actuator.
Old Jun 23, 2019 | 06:46 AM
vr4/sc400's Avatar
vr4/sc400
Lexus part # 69710-53040
Old Jun 23, 2019 | 07:15 PM
Rey06is250's Avatar
Rey06is250
Thank you I just ordered it now. Do you think I would have to take actuator out to connect it ?
Old Jun 25, 2019 | 08:04 AM
vr4/sc400's Avatar
vr4/sc400
Yes, the actuator must be removed to remove/install the cables.
2014GS350F
Jul 22, 2019 07:42 AM
elimmigran
RX - 3rd Gen (2010-2015)
Mar 17, 2019 08:41 AM
pmarr
Jul 20, 2017 06:54 AM
marksexton
May 17, 2007 08:35 AM
enterconne
May 22, 2006 02:39 PM
