Side Window Alignment
Old Jun 22, 2019 | 08:23 PM
Speedin's Avatar
Speedin
Question Side Window Alignment
My driver's front side window seems to leak slightly when going through a car wash. I have already replaced the window channel seal but it seems the windows sits just a little too far away from the window channel seal. Is there a way to align/adjust the angle at which the glass is situated in the door? I can not find this information anywhere.
Old Jun 26, 2019 | 08:34 PM
Speedin's Avatar
Speedin
It would seem no one knows how to do what I am asking here. Does anyone have any information on replacing the driver's front window regulator such as instructions? It might prove helpful to more than just me since this post has received 186 views with no replies other than my own.
Old Jun 26, 2019 | 08:40 PM
xxmariolxx's Avatar
xxmariolxx
Shouldn't be hard to replace. Once you open it up you shouldn't need instructions pretty simple.
Old Jun 27, 2019 | 01:53 PM
2013FSport's Avatar
2013FSport
Once you take the door panel and plastic off, there are **usually** slotted adjustments for the tracks. They don't move far but once you see your options, it may make sense. Usually you find some kind of top/bottom limits but I don't know that part of this car.
Has it ever been wrecked in that area?
Old Sep 1, 2019 | 05:37 AM
Speedin's Avatar
Speedin
Post
**Update**
After adjusting the window regulator to a better position within the door, the window seals much better. It is not obvious to which screws are holding the regulator to the door, so I have attached a screen shot from the repair instructions for replacing the window regulator, which shows all of the screws and tightening sequence.
Broncosi
Jul 14, 2018 09:43 AM
ALLWiTE2JZ
Feb 11, 2015 04:41 PM
hypervish
RX - 1st Gen (1999-2003)
Sep 18, 2010 05:12 AM
tuan92129
Apr 27, 2008 04:04 PM
