Headlights
Old Aug 31, 2018 | 05:28 AM
Bakira10's Avatar
Bakira10
Default Headlights
Hi guys, i want to change my IS250, 07 Lexus headlights but i do not know whether the car fits Factory Halogen Headlights
OR Factory HID/Xenon Headlights. Please help...how do i get to know which one is which
Old Aug 31, 2018 | 06:53 AM
gompka's Avatar
gompka
You should be able to just take a look and see the difference between halogen and hid. Its a striking difference, the only other thing i can think of is if you reach in and remove the bulb, it should be easy to remove the halogen. FYI, if your car has halogen you can't convert to hid, but you can do it the other way around.
Old Aug 31, 2018 | 10:25 AM
2013FSport's Avatar
2013FSport
HID cars will have a Hazard High Voltage Electric Shock label on each light housing. Usually yellow / black.
Old Sep 1, 2018 | 01:52 PM
J2FUEGO's Avatar
J2FUEGO
gompka & Fsport are correct. I also have an 07 IS250. They are the stock halogen D4S bulbs so therefore I am unable to convert to HID. But at least the bulbs I’m replacing them with from KENSUN are cheap they are $30 - 33? And they still look great!
Old Sep 1, 2018 | 02:28 PM
Viru's Avatar
Viru
I'm fairly confident 'D4S' is an HID headlamp, not halogen. The Halogen low-beam bulb fitted to 2IS vehicles is an H11. Correct me if I'm mistaken.
Old Sep 3, 2018 | 11:25 AM
604GSE21's Avatar
604GSE21
don't all 06-08 in North America if equipped w/ HID also have AFS? so if your IS250 have AFS then u should have HID?
Old Sep 4, 2018 | 03:04 PM
whitebeast's Avatar
whitebeast
Some user don’t event know they got AFS.
Old Sep 4, 2018 | 06:37 PM
Viru's Avatar
Viru
Consider posting a picture of your headlamp, we can tell you whether it's HID or Halogen based on that.
Old Sep 5, 2018 | 07:38 PM
whitebeast's Avatar
whitebeast
try to turn on the headlight at night time.
If the light was dim at first then getting brighter, you got HID
If the light bright right away then you have halogen
BennyJ
Nov 2, 2016 02:03 AM
johnpaul21
Jan 5, 2016 06:58 PM
adoan94
Feb 3, 2015 10:36 PM
Arcadian
Lighting
Dec 24, 2010 09:11 PM
Chris4.3
Jun 21, 2009 06:49 PM
