Alternator replacement recommedation
Old Jun 20, 2018 | 10:58 PM
merkin110's Avatar
merkin110
Default Alternator replacement recommedation
Hello,
Would anyone have any recommendations on where to purchase an OEM alternator? I replaced my alternator with one from Orielly's roughly 6 months ago and it appears to have crapped out on me. The symptoms I had where the battery light would come on when my car was under 1500 RPMs and it would go away if I where to rev the engine any higher. It pretty much started dying on the freeway and luckily I had enough juice to exit and pull into a parking lot. I do have a warranty however I am not sure how trustworthy the replacement would be since it went out on me. Also any thoughts on purchasing OEM refurbished alternators?
Thank you
Old Jun 21, 2018 | 08:30 AM
pauls927's Avatar
pauls927
Hi Merkin,
I can't recommend another place for an OEM alternator, but i had a similar issue with the re manufactured one I got from O'rielly as well. My first one lasted 2 years and they replaced it with another one 6 month ago. Lifetime warranty is great, but this in one difficult alternator to change out.
Good luck.
Old Jun 21, 2018 | 02:21 PM
Gville350's Avatar
Gville350
Well, if OEM is what you want, you're options are limited. Dealership or online. Google the P/N and purchase whatever is cheapest.
Old Jun 21, 2018 | 03:11 PM
merkin110's Avatar
merkin110
Any thoughts on re-manufactured ones? Seeing a ton of those online.
Old Jun 21, 2018 | 11:06 PM
V8drummer's Avatar
V8drummer
I just replaced mine with a reman Denso from Rock Auto.
Old Jun 22, 2018 | 11:19 AM
Gville350's Avatar
Gville350
When mine went out, I got an Auto Zone reman unit. Still running strong till this day.
Old Jun 22, 2018 | 06:31 PM
merkin110's Avatar
merkin110
Thanks guys since I do have a warranty and will be replacing it myself I am just going to get a warranty replacement. Now another question once I loosened up the alternator for removal some coolant or something leaked out. Any idea as to why?
Old Jun 23, 2018 | 08:58 PM
sinister2c's Avatar
sinister2c
i think most all replacements remanufactured alternators were once a Denso. They quality depends on who the remanufacters are and the quality of the replacement windings. The 2IS is a fairly easy to reach replacement.
if this were one of the Toyota FWD 350 V6 like in the ES, RX, Sienna or Highlander, I’d definitely spend more on a Denso new since you practically have drop the engine and remove the radiator to access it.
also FYI, Denso does have their “First Time Fit” marketed replacement parts now at a fraction of dealer price. The Denso remanufactured one is around $230 with core trade.
Hbhandal
Nov 30, 2015 01:52 PM
MCCR
Nov 22, 2013 01:46 PM
Gymniac
Nov 18, 2013 12:28 PM
GS4_Fiend
Maintenance
Jan 13, 2010 03:23 PM
landarc
Oct 22, 2005 02:22 PM
