Check Engine Light and VSC flashing
Old Mar 5, 2018 | 06:37 AM
mbetsya's Avatar
mbetsya
Default Check Engine Light and VSC flashing
I have 2007 is250 and the VSC and Check Engine lights are flashing. I am taking it today for service. I do not want to get ripped off...any ideas of what it could be?
Old Mar 5, 2018 | 10:23 AM
Gronemus's Avatar
Gronemus
I would not drive that car much at all with a flashing check engine light. You may end up doing some serious harm to the catalytic converters or other engine components. You need to read the diagnostic code(s) from the ODBII port in order to start diagnosing your problem correctly...
Old Mar 5, 2018 | 11:17 AM
05ls430518's Avatar
05ls430518
you are gonna do irreversible damage if you keep driving it there is a reason its flashing trying to get your attention.
Old Mar 5, 2018 | 06:03 PM
Nitrous23's Avatar
Nitrous23
I've had that and it was my #6 coil that needed to be replaced. I'm not as mechanically inclined as some people on here, but I don't understand how the VSC had anything to do with the coil but it fixed the issue. I will also add that I've had my VSC light come on and off constantly for 5 years and nothing was ever found to be an issue. Once the engine light came on though I got it checked asap. I may have had 2 separate issues. Definitely get it checked asap.
Old Mar 6, 2018 | 08:33 AM
Bichon's Avatar
Bichon
Originally Posted by Nitrous23
]but I don't understand how the VSC had anything to do with the coil but it fixed the issue.
In case you are curious, the reason for the "CHECK VSC" is that the ECU disables traction control whenever the check engine light is on.
Old Mar 8, 2018 | 10:19 AM
Nitrous23's Avatar
Nitrous23
Interesting! Good to know. Thank you
brandon17
Maintenance
Jul 3, 2018 02:15 AM
jankalski
May 21, 2018 10:10 AM
o2012o
Jul 18, 2012 09:49 PM
stvIS250
Oct 23, 2009 08:10 AM
HGill
Jun 15, 2007 10:28 PM
