Engine swap
Old Feb 6, 2018 | 07:05 PM
Tony52's Avatar
Tony52
Default Engine swap
Gonna be swapping engines for my 11' is350 awd. Was curious if it matters if the engine came from a rwd is350? I would imagine I have to get an engine from a awd is350. Thanks in advanced.
Old Feb 6, 2018 | 07:34 PM
Mrfix's Avatar
Mrfix
I'm not 100% sure here but I don't think it matters. Just Keep the old one on hand since you might have to borrow a few things during the swap. The engine itself should be identical.
Old Feb 6, 2018 | 09:23 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
You will need to swap the oil pan and engine mounts, other than that they are the same.
Jeff
Old Feb 6, 2018 | 09:28 PM
Tony52's Avatar
Tony52
Jeff
Okay, so I'm presuming at that point I can just use my old parts right? I wouldn't a problem with that cause the only reason I'm swapping in the first place is a bad head.
Old Feb 7, 2018 | 07:00 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Using your original parts is what I would recommend, yes.
Jeff
Old Feb 7, 2018 | 12:31 PM
Gville350's Avatar
Gville350
Curious as to why you would need to swap your motor out.
Old Feb 7, 2018 | 01:28 PM
Tony52's Avatar
Tony52
The mechanic I went to say I am better off swapping out the motor instead of machining my current motor. Just going with his advice on this one I guess.
jodyjoee
Sep 29, 2015 07:11 PM
itsivan
Jun 1, 2014 11:30 AM
PAVGR
Performance
15
Jun 3, 2012 09:41 AM
ReLexin
Jan 16, 2008 01:11 PM
