Door handle removal
Old Oct 15, 2017 | 01:22 PM
3SPKY5U's Avatar
3SPKY5U
Default Door handle removal
picked up an 08 is350 recently. Need to swap the passenger front door handle as it has some damage. I’ve picked up a new painted one for cheap, just wondering how to pop it off.
I can can only find videos for the RX, which I assume is similar but they lack the electrical connector for the keyless entry.
Anyone done one before?
Old Oct 15, 2017 | 01:29 PM
cleethree's Avatar
cleethree
Typically they are bolted down from the inside. Removing the interior door panel will likely tell the story. How's ft done on the RX? May be similar.
Old Oct 15, 2017 | 01:41 PM
3SPKY5U's Avatar
3SPKY5U
On the RX there’s just a grommet on the side of the door you remove, then unscrew a bolt and remove the handle frontways.
Old Oct 16, 2017 | 12:14 AM
808newbie's Avatar
808newbie
here is a video showing removal of the door panel.
once you have it removed the inside of the door i believe is sealed. remove a portion of it to give you access to the interior part of the door. there is i think two screws (you will need a star bit) to take it off.
sorry for the vague instructions i havent done this in awhile
kinda similar to this though:
gashby
Jun 28, 2019 12:49 PM
simplecar
Apr 21, 2019 07:51 PM
sr20bet
IS F (2008-2014)
Jun 11, 2014 05:55 AM
rtpatter
Jul 28, 2010 01:23 PM
rkh58
RX - 1st Gen (1999-2003)
Sep 24, 2005 10:44 AM
