Squealing, Rumbling and Grinding Engine Noise-- ideas? (Video included)
Hello, I have a Lexus IS 250 2007 with 55K and a week ago my engine developed a squealing noise from the engine. Probably the serpentine belt.
The noise has gotten worse this week and now added a rumbling and almost a random popping /grinding or thud noise as well from the top of the engine area.
Also the serpentine belt had more than 1/2 of play when I pressed it. Closer to 1 inch. it's condition looked good.
I sprayed WD-40 on the Idler pulley and alternator pulley (and some on the belt) the squealing has subsided, but rest of the noises remain.
I made a video as it is very difficult to explain a noise in words.
Notice the clicking after the 40th second of the video...
Ideas on what needs fixing?
Thanks!!
Thanks!!
Since the 2IS is notorious for having water pump issues, I'd start there. But the alternator has also seen its fair share of issues. Lastly, the tensioner pulley has only a few mentioned cases of it needing to bee replaced on here. Less likely to be that.
But the squealing is probably the belt, while the grinding/rumbling noises are probably the WP bearing going completely out.
Inspect the belt since its only one belt driven. Mine has this sound about some weeks ago but it turned out to be something else... GearBox oil pump, i would hear the noise from cold start but after driving about 5 minutes then the sounds become super quiet like a Lexus should be, good luck buddy
I replaced the water pump and that was 100% of the problem. The old water pump with 55k on it had bad bearings and was making the grinding sound. I bought the "Asin" replacement on Amazon for $90 and long life Toyota fluid for $25, the serpentine belt for $20 and $6 for new kit of plastic snaps for the plastic engine cowlings. All in all this job took me all day in my garage, but only needed a few basic tools and the YouTube videos were tremendously helpful. It's been a week now after the replacement and the car is back to normal with no issues. The self tightener of the belt is really nice. I didn't even know those existed! Not bad for less than $200 and about 7 hours of my Saturday. Thanks for the help! I saved hundreds and learned a lot about modern car engines!
Skier76 (10-17-17)
shinbo
02-14-18 04:06 PM
adriann829
10-27-16 05:32 PM
