Car starts shaking some when braking?
There's a lot of information out there about brakes. Here's what matters to us from Toyota/Lexus:
That's step 4C of the front brake inspection procedure. So, let's forget the word warp. Let's call it runout. That's what Toyota calls it. Their engineers have been doing this for a while. I'm sure if they think it's real... it's real. But I am more likely to believe that composite rotors do not develop runout... They just get traded in because most people can't afford to replace them ;-)
In truth, nobody can diagnose your car via the forums. A brake pulsation is a symptom of a condition. You'll need to perform a thorough inspection in order to determine how and why this symptom presented itself. If I were your mechanic I would not start doing anything to your car until I can explain why you are experiencing the condition you're concerned with.
If your brake pulsation manifests itself in a vibration of the steering wheel at moderate speeds, I'd focus on the front brakes. If the vibration is felt more in the seat of the pants, I'd focus on the rear brakes. If the brake pedal seems to be slightly spongy, I'd scrutinize the calipers and hardware... etc, etc, etc.
P.S. I've had more success eliminating runout using an on-car lathe rather than a bench lathe. Toyota recommends the use of an on-car lathe for their products as these machines calibrate to the vehicle and reduce runout accordingly, well, ProCut does.
And not all technicians are the same. Some are much better than others at resurfacing brakes.
If the runout exceeds the maximum value, change the installation positions of the disc and axle so that the runout will become minimal. If the runout exceeds the maximum even when the installation positions are changed, check the bearing play in the axial direction and the axle hub runout
. If they are normal, and if the disc thickness is not within the specified range, grind the disc. If the disc thickness is less than the minimum, replace the disc.
Last edited by leoferus; Aug 11, 2017 at 11:52 AM. Reason: Forgot to add something.
Rotors don't warp. They will sometimes get an even surface from deposits from the pad, but they do not warp. Resurfacing only takes material off the rotor, it's an unnecessary process. Measure the thickness of the rotor to see if replacement is necessary, If it is not. Perform a bedding in process to remove the deposits and transfer pad material to the rotor. Measure the pad thickness also to see if replacement is necessary.
http://www.stoptech.com/technical-su...nd-other-myths
Lou
Lou
Unless you go with synthetic DOT4, the conventional DOT4 is more hygroscopic and absorbs moisture nearly twice as fast as DOT3. Yes, it has a higher boiling point but it comes at the cost of replacement every two years. If your climate has agressive swings from winter to summer it should be done annually.
So its all in a word run out or warped, if you have ever watched brake drums or discs being machined you would see a lot of metal coming off the warped - run out area . I have worked on buses trucks and plenty of old and new cars, in this day and age of throw away society sometimes it makes no $ sense to machine a warped, run out disc which is the major cause of brake shudder.
mikhett
RX - 1st Gen (1999-2003)
Aug 14, 2018 06:26 PM
