Spec d lights
Jul 23, 2017 | 05:02 PM
Jul 23, 2017 | 09:15 PM
Looks like you just pull it straight off from the white plastic connector (what you're holding onto). Looks to be 1-pronged.
Jul 23, 2017 | 09:26 PM
^what he said. should be able to pull it straight off or at least wiggle it off.
Jul 23, 2017 | 09:43 PM
It was pretty hard I even tried wiggling it out, I felt like I was breaking it more then anything I'll have to give it another try
Jul 23, 2017 | 11:38 PM
H1 bulb is pulling straight out. It's little hard but do able. Don't affair, it wont break that easy
Jul 24, 2017 | 11:23 AM
Awesome thanks I'll give it another try today after work also, do you have any idea why one. Of my blinkers is blinking super fast compared to the other? I just started doing it when I installed the lights it didn't do it
Jul 24, 2017 | 08:27 PM
LED will blink faster, that is why you need cambus resistor to correct it ( the voltage drawing is different between the halogen and LED)
Jul 25, 2017 | 09:41 AM
If you're still having trouble with this bulb, try wrapping a piece of duct tape around it, then pull. The duct tape will also keep glass from going everywhere if it breaks. In regards to your blinker question, yes, ^^what whitebeast said.
Jul 25, 2017 | 10:09 AM
If you want to separate the bulb, DONT PULL IT STRAIGHT OUT!!
there is a pin on each side that bites into the bulb. Just look closer.
It reverse clicks in. You'll need to use something like a paper clip to bend the pin out then you can pull it out.
if you just want to detach the whole bulb assembly from the car wire, just wiggle and pull from the white connector.
LexiSoSexi
IS - 1st Gen (2001-2005)
13
Mar 28, 2011 12:21 PM
tomtsops
Lighting
Jan 1, 2008 08:32 PM
lawlor8042
Apr 3, 2007 07:25 AM
rfm001
Lighting
Dec 22, 2004 08:34 AM
