Carbon Buildup fixed, lower octane gas?
Almost every auto maker on the planet recommends 93 octane, or says requires. Not because it can be a problem for the car running 87, but because the ECU will adjust the timing etc to 87 and produce less performance, which to auto makers means that their/your car doesn't perform like they say it will. I can live with 10-20 less HP most of the time and save 30-50 cents a gallon (or a bit over $15 bucks a fillup). I can always fill up with 93 when I feel like it or, just pop a bottle of octane boost in for way cheaper. The ECU will adjust back very quickly and your on fire again. There are absolutely no harmful effects to any OBDII motor of putting in regular. Look it up. Google it. Research it.
http://www.roadandtrack.com/about/a31295/high-octane/
Can't get much clearer than this...
"With 16.5 million U.S. drivers having used premium fuel despite the vehicle manufacturer's recommendation"
"High-performance engines take in higher-octane gasoline because they need it to operate at their peak potential"
"What AAA found out was that premium gasoline in a car designed for regular didn't produce better fuel economy, reduce pollution, or make your car go faster—in short, all it did was take a bit more of your money."
"Researchers tested different grades of gasoline in a variety of engine types, checking everything from power output to tailpipe emissions. And they found no benefits of higher octane." That is a test for using higher octane gas in engines where the manufacturer did not recommend higher octane.
You are spreading bad advice based on your twisting of that article. PLEASE STOP!!!
Geeze, Man! That article is about people using premium gas when it's NOT recommended. The contrary that you have extrapolated is not a fact!
The key is...recommended or required. Recommended means you can run anything through it with a minor performance drop and no mechanical fears. Required means you can run 87 through it a good amount of time, but mostly premium. Both grades have the additives that are beneficial to keeping motors clean. Google the darn issue before you flame me please. Do some research. I can send you hundreds of links where it's been discussed and analyzed if you can't find them on the net. Join the 21st century and go see for yourself. It is not bad advice and it's based on fact. End of discussion for me. Believe what you want. It appears that you have decided to do so in the presence of plenty of info that says otherwise.
Please provide some of this "plenty of info that says otherwise" to back up your conclusions. You made the statements to not listed to Lexus on this one based on "plenty of info" I simply want to see some definitive info other than your continued claims that states such as facts.
87-recommended...zero problems, none.
87 required-yes, CAN cause problems in long term use under certain circumstances.., IF you go to car's performance limits a lot (i.e WOT). Now, really how many of us go at 90-100% WOT often? 100% WOT is for races, 0-60 times and quarter times and the occasional 60-80 pass. Maybe 5% (if that) of driving time over the life of the motor. If you don't hear ping or knock, it couldn't have hurt. If you do once or twice, you'll know for sure and you won't do it again. A few won't hurt anything.
Now I'm done. You can find all the info you need yourself. I'm not going to do for you what you can so easily do yourself. Geez..I feel like I'm on Facebook now in a political discussion...
Andysavage
06-28-21 12:14 PM
meis250
09-19-12 09:11 PM
