Transmission flush
Old Oct 11, 2018 | 05:06 PM
  #31
bazzle01's Avatar
bazzle01
I would be checking rear diff.
Have a look for leaks, check level.
Next thing ensure pinion nut is tight.
Some Toyota's are known for them loosening.
Old Aug 4, 2021 | 11:55 AM
  #32
User 122922's Avatar
User 122922
great to hear that would you please tell me how’s your car performs after this flush, since I’m going to use Amsoil signature series and I found a qualified Lexus mechanic will perform a machine flush and ask me to bring around 16qrts, I have 2008 Lexus GS 350 with 111mi on it , I was reading here and there about flush not a good idea with high mileage but I heard also good results as well, most of them they recommend me doing just drain n fill which will drain only 3qrts at a time !! Would you please give me your honest opinion should I go ahead do the flush or should I stick with the drain n fill ? By the way the mechanic took the car for test drive and told me your transmission shift smooth and I don’t see no problem at all, but I told him the history of the car says it’s never been had any transmission service! Thanks for your time looking forward to hear ya
Originally Posted by SeanO
My car is 6 speed auto and RWD.
My car had the fluid flushed - so it was pump in and pump out temperature controlled the entire process.
Old Aug 4, 2021 | 04:22 PM
  #33
User 122922
I know it’s been along time since you post this but I’m wondering how your car perform after switch to Amsoil signature series ? And did do you a complete flush or just a drain n fill ? Please share your experience since I’m really confused and not sure should I do the flush or just drain n fill, my car has 110mi now and it’s never done any trans service before ! Thanks for your time
Originally Posted by primavera
Hi everyone,
I'd like to switch to AMSOIL Signature Series Synthetic Automatic Transmission Fluid (blue cap bottle) instead of Toyota's ATF WS fluid.
My question is how many quarts / liters of fluid do I need to buy to perform this flush? Can anyone chime in?
Thanks for your help.
https://www.youtube.com/watch?v=WQ-DnON3gbg
Old Aug 4, 2021 | 06:21 PM
  #34
2013FSport's Avatar
2013FSport
I wrote a DIY #2IS thread on this topic if followed to the letter, one can dump more than 1/2 out in one flush. See below.
PS Amsoil went back in mine also.
2is-transmission-fluid-change-diy-a760e-rwd
rainmn
GX - 1st Gen (2003-2009)
Mar 16, 2011 11:28 AM
ThePill
Mar 24, 2008 02:04 PM
gadgeeets
Performance
Apr 4, 2007 07:10 PM
LazyAlex
Performance
Dec 16, 2006 10:32 AM
Bobk528
RX - 1st Gen (1999-2003)
16
Sep 26, 2005 07:34 PM
