TPMS "Check System" HELP
Old Jan 31, 2017 | 12:00 PM
CarolinaI3's Avatar
CarolinaI3
Default TPMS "Check System" HELP((SOLVED))
I recently purchased my 2006 IS350, LOVE IT, but the other day i hit a nasty pot hole and imidiatly the TPMS CHECK SYSTEM came on the info screen along with the triangle ! and the actual tire light in the bottom right corner of the cluster. I have taken it to Discount tire and they tested all of the wheel sensors, they are good. The tech said it could have knocked something loose on the ECU. Before i take it to the stealership/dealership does ANYONE know a possible fix and where the ECUs are located. I have also read somewhere there is a wire behind the radio that could get "pinched".
Also the air bag light is on in the bottom right of the cluster(has been since i purchased the car) any idea what the fix could be for that? THANKS!
I removed the radio and found that the TPMS ecu harness had come loose. I reattached it and zip tied the harness to the ECU. Now on to the air bag light....
Old Jan 31, 2017 | 12:06 PM
jjc250's Avatar
jjc250
Codes please...
Old Jan 31, 2017 | 12:52 PM
CarolinaI3's Avatar
CarolinaI3
Originally Posted by jjc250
Codes please...
I have my ScanGauge hooked up and it's not reading any codes
Old Jan 31, 2017 | 03:13 PM
Solara350's Avatar
Solara350
check your tires pressure for leak, the wheel that hit the pothole might be damaged the TPMS sensor, TPMS is inflation for the wheel, they will not give codes it's not a Check Engine, Discount tires said it knocked the ECU ? my opinion, your TPMS sensor might be broken. if ECU damaged it won't give u the warning light. check tires pressure 1st and then sensor.
Old Jan 31, 2017 | 03:25 PM
whitebeast's Avatar
whitebeast
Bad TPMS ECU still give out the flat tire warning light. The TPMS ECU is located on top of the Navigation screen.
When you turn on the car, if you see warning light blinking then either bad TPMS (more chance) or UCE itself.
If it be soiled then check air pressure again. I would think your TPMS is damage
Old Jan 31, 2017 | 04:42 PM
CarolinaI3's Avatar
CarolinaI3
The wheel is slightly bent at the flange but it has held the same air pressure for the past 3 days.
Discount tire put a reader by each tpms sensor and each sensor responded.
I do not have navigation, would the ECU be in the same place?
when I turn on the car the pressure light in the right corner blinks for a min then stays solid. The check system light comes on and stays solid.
Old Jan 31, 2017 | 06:15 PM
sktn77a's Avatar
sktn77a
Have you tried resetting the TPMS system?
Old Jan 31, 2017 | 06:44 PM
CarolinaI3's Avatar
CarolinaI3
Ive tried but I'm not sure if I was doing it right. I found a few treads on here but no 2 were exactly the same process.....
87vertgt
Dec 13, 2018 10:13 PM
CBlansett
May 13, 2017 06:36 AM
Gustavo621
Feb 23, 2017 06:23 AM
sprocket
GX - 1st Gen (2003-2009)
18
Dec 13, 2015 04:23 PM
Rontrell
Jun 2, 2015 03:58 PM
