Did Lexus Change The Maintenance Schedule on the IS?????
Old 08-27-16, 06:11 PM
355F1
355F1's Avatar
Default Did Lexus Change The Maintenance Schedule on the IS?????
I have a 2010 IS 250 AWD and this first photo is from the original maintenance schedule that was on the Lexus Driver's page before the page got redesigned--and is also in the manual.
The second photo is what it is NOW telling me I need for my upcoming 150k miles service.
What the heck??????
Some IMPORTANT things are missing from the NEW SCHEDULE!!!! (I am obviously going to change the coolant and brake fluid but why isn't it on the new schedule????)
Attached Thumbnails Did Lexus Change The Maintenance Schedule on the IS?????-old.png   Did Lexus Change The Maintenance Schedule on the IS?????-new.png
Old 08-27-16, 07:12 PM
leoferus
leoferus's Avatar
When I look out the 150k mile service interval this is what comes up:
150,000 Miles or 180 Months Recommended Service
Reset Oil Maintenance Reminder, if Oil was Changed
Perform Road-Test on Vehicle
Rotate Tires
Inspect Ball Joints And Dust Covers
Inspect Brake Lines And Hoses
Inspect Rear Differential Oil
Inspect Steering Linkage And Boots
Inspect Brake Linings/Drums And Brake Pads/Discs(1)
Inspect Exhaust Pipes And Mountings
Inspect Steering Gear Box/Rack And Pinion
Inspect Drive Belts
Inspect Fuel Lines And Connections, Fuel Tank Band And Fuel Tank Vapor Vent System Hoses
Inspect Fuel Tank Cap Gasket
Inspect Axle Shaft Boots
Inspect Body
Inspect Front Differential Oil (4WD/AWD, If Applicable)
Inspect Transfer Case For Signs Of Leakage (4WD/AWD, If Applicable
Inspect Transmission for Signs of Leakage
Replace Engine Oil And Oil Filter(2)
Replace Engine Coolant
Replace Engine Air Filter
Replace Cabin Air Filter (If Equipped)
Replace Brake Fluid
Replace Smart Key Battery
lychee416
11-17-18 02:05 PM
babiibryan
05-01-18 09:45 AM
GregCanada
09-16-14 09:22 AM
2wne47
04-26-12 09:10 AM
ziggyziggy
RX - 3rd Gen (2010-2015)
10-20-11 01:28 PM
Quick Reply: Did Lexus Change The Maintenance Schedule on the IS?????
