Help!!!! [sound with car in neutral]
Old 11-24-14, 06:31 PM
beckyp84
beckyp84's Avatar
Default Help!!!! [sound with car in neutral]
Hey all,
Have a 2008 Lexus is250. 37k miles. When I got home today from a long drive to and from work (120 miles), I noticed a loud sound almost a banging sound when my car was in neutral. It's a manual model. Had my neighbor and brother in law listen to the car. They both said the water pump was bad. I have ZERO warning lights on in my dash. Car has not overheated etc. Heater does take some time to warm the car. Question, I have to go to and from work tomorrow (120 miles), before being off for the holidays. Is it safe to drive with no warning lights on? Have an appt with my mechanic for Friday. Thanks so much!
Old 11-24-14, 06:36 PM
Gville350
Gville350's Avatar
Can you narrow down where the sound is coming from? With the vehicle running, can you hear something a slight grinding or bearing "whirring" noise? With the engine off, check under the water pump area for pink crust (aka, leaking coolant).
Are you sure it wasn't the clutch/pressure plate when shifting out of gear into neutral?
Old 11-24-14, 06:39 PM
beckyp84
beckyp84's Avatar
It is more of a knocking sound I guess. No pink or leaking anything for that matter. We left it running a good 10-15 mins and the sound continued Seems to be driving just fine.
Old 11-24-14, 06:57 PM
Gville350
Gville350's Avatar
Does it sound like it is coming from the front area of the motor or the driver side OR behind the motor? Does the vehicle shift fine with both the car off AND on?
Old 11-24-14, 06:59 PM
beckyp84
beckyp84's Avatar
It seems to be more towards the drivers side or middle of the motor. I haven't tried shifting with the car off. Shifted fine while driving. My brother in law also said he felt that something was loose? Just worried about my commute tomorrow before getting it into the shop.
Old 11-24-14, 07:29 PM
aspeckt
aspeckt's Avatar
my water pump symptons were a clanking noise from my engine bay and my car not heating up. this was during the winter. my car overheated about 30 mins into a trip to savannah. had to get towed back to a shop.
Old 11-24-14, 07:42 PM
beckyp84
beckyp84's Avatar
How long was the clanking noise hapenning before it broke down? I noticed it today for the first time.
Old 11-25-14, 03:55 PM
Gville350
Gville350's Avatar
Remove all of the engine covers you can and then check for the noise. You should be able to narrow it down that way.
Old 11-25-14, 05:01 PM
ivnnln
ivnnln's Avatar
For a 120 miles commute, I would not take it for tomorrow work. I rather do a car rental just to be safe that you won't be strained on the road, and to further damage any internal part.
Just my two cent.
Old 11-25-14, 05:11 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I wonde of Becky went to work today in the 250?
Old 11-25-14, 05:26 PM
pmanliu
pmanliu's Avatar
Shall we send the CL search & rescue squad?
Old 11-26-14, 12:07 PM
Gville350
Gville350's Avatar
Becky? LOL
Old 11-26-14, 04:45 PM
nosurprise
nosurprise's Avatar
I guess she took the time to make a very deformed snowman.
beckyp84
11-24-14 07:28 PM
VGer
06-12-14 12:46 PM
Acingteam
05-16-12 02:30 AM
xioix
Maintenance
12-23-11 10:29 PM
LPA
SC- 1st Gen (1992-2000)
03-20-11 08:38 AM
Quick Reply: Help!!!! [sound with car in neutral]
