Head light goes out 15 min after its turned on
Guess im going to order 1 bulb from lexus see if thats it.. Was told by afew people that the ones i got were philips bulbs just that they didnt have it printed on them, but came from the same factory in germany then shipped to china to be put together.. It has the germany stamp on it or something like that.. A good friend that has used these bulbs 100 times in all sorts of diff cars have never had a problem. But I'm starting to wonder. Sometimes things that are to good to be true arnt so good. lol
Like I said, swap the bulbs, see if the faulty light follows the bulb or ballast. Once you realize it's the bulb, pick up a set from Xenondepot. The OEM ones will cost you a fortune and the Chinese bought ones are much more likely to be crap.
If you listened to my advice from the start you wouldn't have an issue still.
Thanks for the help geta. BTW both bulbs were going out so trying the other wouldnt of helped.
Hi guys! I'm experiencing both of my lights going out. After reading the thread I'm considering replacing the bulbs. Both of my headlights go out. Sometimes it's the left and other days its the right. I quickly notice this and switch them on and off and it turns it back on. I've been in this situation for months and it's time I move forward with new bulbs. Hope this takes care of this issue. Would appreciate any suggestion on bulbs and any other advice. Thanks!
May be a good time to switch to 6000K bulbs for better visual appearance, if that's your taste.
You really should have just not been lazy and swapped the bulbs. Found the real issue, then gone from there.
If it's the bulb, you should have gotten 2 new bulbs, either OEM, Xenondepot or Garax bulbs and replaced both.
If it was the ballast, then just replace the one ballast.
After about a year and a half, one of my Xenondepot D4s 6000K bulbs has stopped igniting properly. After swapping the bulbs to verify, I contacted Xenondepot. Unfortunately, since it is after a year since the purchase, there is no warranty.
While they did reply promptly and offered a slightly discounted bulb, I have decided to try a set of Chinese bulbs instead. My fog light HIDS that were about $30 for bulbs and ballasts are still functioning properly, so I figure it's worth a shot with the headlights as well. Anytime my headlights are on, so are my fog lights and both were replaced at a similar time.
CJITTY
09-14-11 06:13 AM
NovaIS350
10-05-09 10:29 AM
