help!! coilovers
Old Jun 11, 2014 | 10:52 PM
08wis250's Avatar
08wis250
Default help!! coilovers
friend helped me installed meganez coils and told me he couldn't put the rear sway bar back in place I'm thinking he did something wrong thanks !
Old Jun 12, 2014 | 12:06 AM
JdSwiper's Avatar
JdSwiper
What end links are you using??
Old Jun 12, 2014 | 01:08 AM
08wis250's Avatar
08wis250
oem he was telling me i needed aftermarket ones to put the sways back on and all a chamber kit is this true?
Old Jun 12, 2014 | 01:29 PM
Gville350's Avatar
Gville350
Your friend doesn't know jack....sorry. There's no reason why you shouldn't be able to use the stock sway bar and end links with those Megans. What probably happened was he discovered the end links were rusted up tight and cut them off to help him install the Megans. Same with the camber kit, not 100% needed when running Megans.
Old Jun 12, 2014 | 01:30 PM
NXXT's Avatar
NXXT
You need to jack up the rotor to remove the pressure off the sway bar in order to put the bolts back in
Old Jun 12, 2014 | 01:49 PM
laobo979's Avatar
laobo979
I guess you buddy doesn't know what he's doing. Cause you should never have to touch or remove the sway bar to install suspension on these car.
Old Jun 12, 2014 | 02:13 PM
BoyOhBoy's Avatar
BoyOhBoy
Like he said. You do have to make sure that both sides are unbolted so one side doesn't have more pressure than the other.
Old Jun 12, 2014 | 04:49 PM
MrBalistic's Avatar
MrBalistic
Im currently running Megan Racing LP Coilovers with no aftermarket end links or camber kit and my sway bar still fits perfect without any problem, and like the other poster said, you do not need to touch the sway bar to install the coilovers
Old Jun 12, 2014 | 10:40 PM
08wis250's Avatar
08wis250
thanks for the reply guys!
Old Jun 21, 2014 | 02:39 PM
08wis250's Avatar
08wis250
still haven't got the sway back on yet any tips i can get the sway back on brackets but the end links wont fit into place would taking of the end links of the bar and putting in those first then the sway work ?
Old Jun 21, 2014 | 09:01 PM
MrBalistic's Avatar
MrBalistic
since your having so much problems, I would say remove the coils then reinstall back your endlinks and stabilizer bar then after that's in then reinstall back the coilovers without touching the stabilizer bar.
GKLCPA
Nov 26, 2011 08:39 PM
termigator
Apr 22, 2009 03:33 PM
Frankdorn
Suspension and Brakes
Feb 7, 2009 06:59 PM
TexasGS
33
Nov 1, 2005 03:49 PM
George Hsieh
Nov 20, 2003 06:42 PM
