IS 350 cooling system issue..HELP!
I used a Denso radiator, beck arnley thermostat, OEM readiator cap and an OEM aisin waterpump.
Yet after replacing all of these the temperature guauge needle would get to operating temp but if the car was ran hard the temp guauge would drop down some and sloowwwlly climb back up to normal operating temp. So just 2 days ago I replaced the coolant temp sensor(thinking it was the sensor malfunctioning)
Each time i opened up the cooling system i attempted to purge air from the system using this method: leave rad cap off, bring car to operating temp(when fans kick on) let the fans come on 2 or 3 times then shut it off. I made sure the heat was set high. Fan on. I even tried with the fan off.
I have no clue what is going on with this piece of ****, can anyone help me as to why my temp gauge is doing this even though i have replaced everything dealing with the cooling system?
Lobuxracer I hope you can comment, you always seem to know when stupid **** happens to these cars what to do.
BTW i also own an IS300, it is my lil baby.
When you had the radiator cap off to blurp the system, did you had more coolant as the level dropped? What you mentioned I did exactly the same thing to ALL of my Hondas; I only additionally added new coolant each time the level dropped when the fans kicked in. Yeah, 2-3 fan cycles was plenty too. '
GL!
I used a Lisle spill free funnel to fill up the car. AS the car heats up the fluid builds up into the Lisle spill free funnel. I then allow the car to cool and it sucks the fluid back down into the radiator cap. but yes Gville350 it is currently my only issue. I know something has to be wrong.
I feel like its air in the system possibly and I am just not doing something right to bleed it correctly.
If it was the headgasket my car wouldnt run as good as it does would it? Idle is smooth and power is all there throughout rev range.
oh yeah I even replaced each thing in the cooling system i listed above seperatley each time. trying to pin point the problem, starting with the radiator, then the cap, then the thermostat. and finally the waterpump(waterpump did have a small leak from weep hole). and lastly the coolant temp sensor
one more thing I did was open up passenger side of the block to drain coolant but couldnt get to the other side(drivers side was a *****). I know that allowed more air to enter the system
use the lisle funnel or dont?
break down how you would do it step by step, i am a little slow
It won't work exactly like this with the IS-F because the reservoir is pressurized too. I'm pretty sure the IS250 and IS350 are the same. You have a plastic cap on the reservoir and it is what actually holds pressure. I haven't had to do anything with my F yet, but if I were, I'd do pretty much the same thing - add coolant to the full line, massage the hoses cold to get out as much air as possible, fill to the FULL line, cap it and start the engine. One up to temp, massage the hoses again and let it run for a bit, maybe take it for a 20 minute drive somewhere, then let it cool enough to be able to safely remove the cap, add coolant (if necessary) and put the cap back on. At that point, I"m done and will only check the level after a week or so in case any small bubbles managed to purge themselves.
The problem with running the engine with the cap off is it's really hard to get the system to the right level. The cap is meant to pressurize the system, but with the cap off, that can't happen. So the coolant expands, you get some air bubbles out, and then cap it hot. Without any pressure, the self adjusting feature of the closed system doesn't work, so the level is wrong and there will likely be air in the system. Then you have to go through purge cycles and a bunch of other crap I hate to do, so I quit doing it that way a long time ago. It's even more important when you run a high pressure cap (as I do on my Supra) since the idea is to run a more water biased coolant mix and improve detonation resistance. To do this, you must have a higher pressure cap to prevent boil over because the boiling point is considerably lower even though the heat capacity is higher.
Anyway, I'd focus on massaging the hoses with the cap on and the system at normal operating temperature. I"m going to assume you are smart enough to realize it's a bad idea to grab a hose full of coolant at 180F with bare hands...
If you want to learn a lot about cooling systems from a reliable source, not just some shadetree wrench on the web, go to Stewart Components and get some really useful technical info on what to do and not do to your cooling system.
On my is250, I've changed the coolant 2 times just drained and
refill, letting the car run and paying attention to the radiator cap and ull see when ur coolant cycles through the system. Do u see ur coolant cycling when the thermostat opens?
1. Try oem thermostat
2. Do a pressure test to see if ur loosing any, if so there's a leak somewhere.
3. Do a combustion test to see if ur gasket is really blown to eliminate this from ur check list. Since if the car was smoking meaning the car was driving when overheating.
Seems like u have done all the bleeding already and it is still spiking.
