Tyre Pressure Light
Old Mar 22, 2014 | 09:38 AM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
Originally Posted by tex2670
Why would you use that switch, when there's one easily accessible by the steering wheel?
Because the one below is the reset switch. The satellite control you're talking about merely toggles between two different sets of TPMS
Old Mar 22, 2014 | 01:33 PM
tex2670's Avatar
tex2670
I guess they changed it for MY '08, because on my 07, the first "page" says "INITIAL" to initialize the monitors, then the next page is to toggle between the MAIN set of tires and the 2ND set. So, if the OP needs to reset, he should use the button next to the steering wheel--there is no button under the dash.
Old Mar 24, 2014 | 06:26 AM
Chilo's Avatar
Chilo
There's still an actual TPMS button bellow the dash on the IS, similar to the one of the GS posted above. These satellite controls allow you to toggle between two different sets of wheels with TPMS programmed
i have tried most of the suggestions written here but the thing won't go off
Old Mar 24, 2014 | 08:15 AM
tex2670's Avatar
tex2670
Sounds like you need new sensors.
Old Mar 24, 2014 | 11:59 AM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
Tex is right, it may just be a faulty sensor in this case if the light won't go off.
Old Apr 4, 2014 | 09:40 AM
Chilo's Avatar
Chilo
thanks, i will probably need to check with my tyre dealer
Old Apr 4, 2014 | 09:41 AM
Chilo's Avatar
Chilo
I am wondering where to find the location of my gear box oil
Old Apr 5, 2014 | 03:20 AM
Chilo's Avatar
Chilo
Default Yehaaa, Pressure warning light is gone
finally the pressure sensor light is gone. took the car to a technician to wipe off the signal and he discovered the the sensor were not transmitting information to the system, the guy could not fix it but wipe off the warning light but before i got home the warning light came back up. at of frustration this mrning i decided to find the solution on my own, i click the setting button on the dash board and recalibrated the tyres, there after i use the satellite switch to navigate to initiallize the tyre, i held the button down till i heard a beep sound i put off the engine of the car, turn it to ignition mode repeated the initialization again and to my amazement the warning light went off. Yehaaaa
CAT6303
Sep 15, 2018 08:34 PM
Ironman50
Dec 10, 2014 05:30 AM
kknguyen11
Oct 1, 2014 04:16 AM
tyb2639
GX - 1st Gen (2003-2009)
Jan 21, 2012 07:08 PM
Marexus
Jan 12, 2012 06:15 AM
