Rwd differential fluid change
Old 03-09-14, 05:57 AM
Ants350
Ants350's Avatar
Default Rwd differential fluid change
Hi I have a 2007 Lexus is250 RWD I don't see anywhere in the maintenance Manual about RWD differential fluid change does it need to be change?? I'm only finding for cars with AWD. Thanks.
Old 03-09-14, 08:18 AM
FSportJoe
FSportJoe's Avatar
This may help you out!
https://www.clublexus.com/forums/is-...il-change.html
FSportJoe
Old 03-09-14, 09:58 AM
JETLEX
JETLEX's Avatar
If you're near the 60K maintenance mark, I would go ahead & change it - mine was pretty dark, as with most others if you search around on here.
I purchased a small hand pump from Harbor Freight to do it - made it easier for me.
HTH
Old 03-10-14, 05:05 PM
jamessinh
jamessinh's Avatar
I changed mine.
Old 03-10-14, 06:01 PM
tomiv9
tomiv9's Avatar
Does it need to be changed with AWD??
Old 03-10-14, 06:18 PM
NYKnick101
NYKnick101's Avatar
yep... AWD differential fluid needs to be changed as well. I changed mine at 80k
Old 03-11-14, 12:00 AM
jamessinh
jamessinh's Avatar
AWD, 4WD, RWD, FWD...... I would change them. I changed my 4WD GX470 and RWD IS350.
Old 03-11-14, 01:43 AM
Ants350
Ants350's Avatar
Ok I just didn't see it in the maintenance manual is more of a preventive maintenance for rwd .What's the worse thing that can happen? Thanks
Old 03-11-14, 05:52 AM
4TehNguyen
4TehNguyen's Avatar
its cheap and easy to get to, might as well do it
LexusFirst
04-02-15 12:46 PM
tomiv9
09-09-14 07:18 AM
LexStylez
11-23-13 10:39 AM
ajay60610
09-25-13 07:21 PM
Quick Reply: Rwd differential fluid change
