IS250 Differential Oil Change
Hi,
I wanna change the differential fluid. I'm not sure the dealer shop would change it with a synthetic oil other than the OEM. I ordered 2 quarts of Red Line 75W90 Synthetic Gear Oil and will bring it to a nearby dealer shop. Is it possible?
I'm in College Park, Maryland. If you know a better shop to do the job, please let me know. I think the dealer shop may be expensive although I bring all the oil.
Not sure if same on all 2IS but you'll get the idea. 2 quarts of oil is all you'll need.
https://www.clublexus.com/forums/is-...hange-diy.html
Unlike the transmission it can be changed... but I've yet to see anyone present a genuine good reason to, especially since it's not even a limited slip diff... and the owners manual certainly never calls for doing it.
I'm sure any dealer will be happy to take your money if you insist on it though
Keeping it Real
It's not really electronic actually. They call it a semi-LSD, as there is a mechanical preload device inside the differential that helps with traction when trying to get moving on low-traction surfaces. The electronic aspects are mostly just traction control (throttle-limiting) and stability control.
Jeff
Jeff
