Headlight washer
Old Feb 21, 2014 | 07:17 PM
Fsport22's Avatar
Fsport22
Default Headlight washer
Has any one ever taken out the head washer fuse and does any light come up on the cluster when it was taken out
Old Feb 22, 2014 | 06:15 AM
Bichon's Avatar
Bichon
Why do you want to do this? If the answer is that you don't like the headlight washers activating whenever you wash the windshield with the lights on, then I've got a MUCH better solution:
https://www.clublexus.com/forums/is-...ml#post2299117
Old Feb 22, 2014 | 06:29 AM
laobo979's Avatar
laobo979
Isn't there just a switch for the headlight by its self? Well at least for mine is a switch by the sunshade visor. So it doesn't come on with the windshield one.
Old Feb 22, 2014 | 07:24 AM
Bichon's Avatar
Bichon
That's the whole point of the mod above. There is a separate switch to activate the headlight washer by itself, but the headlight washer also comes on when activating the windshield washer if the headlights are on. Performing the mod removes that unwanted link, meaning the headlight washers ONLY run when the switch is pressed.
Old Feb 22, 2014 | 07:27 AM
synrgy350's Avatar
synrgy350
Yes, you can take the fuse out without any warning lights on the dash. I did this because my passenger side washer nozzle broke, and it would cost over 200 to replace. I never really needed them here in California anyways. The fuse is located under the hood. Good luck!
Old Feb 22, 2014 | 07:30 AM
Joeb427's Avatar
Joeb427
Isn't just easier to pull the headlight wash fuse?
Fuse #32 in the FS.
Any problem with pulling the fuse?
Old Feb 22, 2014 | 08:09 AM
Bichon's Avatar
Bichon
Fuse #32 in the FS.
Not that much easier. Popping the fuse out or popping the wire out of the connecter are both five minute jobs, but the latter leaves the headlight washers functional should you ever want to use them.
Old Feb 22, 2014 | 08:22 AM
Joeb427's Avatar
Joeb427
I see,thanks.
I don't think I'd ever use the headlight washers.Never did on an IS I owned.
Old Feb 22, 2014 | 02:58 PM
Fsport22's Avatar
Fsport22
Thank u guys
sandy14
RX - 4th Gen (2016-2022)
57
Apr 19, 2025 08:55 PM
jakenbake
Dec 12, 2023 03:37 AM
Mikelundin
Apr 11, 2017 05:45 PM
iamviolet
Sep 4, 2010 05:35 AM
Kailua250
Apr 12, 2006 07:07 PM
