Stranded with VSC plus error code PO193
Old Oct 8, 2013 | 01:58 PM
350stew's Avatar
350stew
Default Stranded with VSC plus error code PO193
Well got the dreaded VSC , engine check and traction lite up on my dash.
Scanned for codes and PO193 comes up = Fail Fuel Rail Pressure Sensor Circuit High Input.
Symptoms are first start it stalls then second attempt it starts but get limited power. Need to start slow and build up my speed to 30 mph if lucky.
Checked the gas cap ,then did the battery reset and reset again with OBD. Last I tried the brake dance to see if I could deactivate but just reverts back to VSC.
Looking for ideas and pictures on how to trouble shoot the problem before I get robbed by the dealer
Thanks anybody?
2006 is350
Old Oct 8, 2013 | 02:39 PM
draketodd's Avatar
draketodd
Check all of your fuses. The issue you are having could be very different than what I have experienced. But every time I blew a fuse, the VSC, check engine and trac light came on. Hope this helps.
Old Oct 8, 2013 | 04:20 PM
350stew's Avatar
350stew
Thanks draketodd ...... I will check out the fuses
Old Oct 8, 2013 | 06:16 PM
350stew's Avatar
350stew
Did some digging and decided to start with the engine compartment fuses.
Focused on what I thought could be related to this problem
#1 is a 25 amp fuse for the VDIM circuit. It was easy enough to remove and checked out fine.
The next fuses that I wanted to inspect were in the same compartment but had an extra clear plastic cover over them held in place with four small tabs.
I didn't think I could remove this cover without breaking it so.... I just used a flashlight to get a closer look.
Started with # 12 a 50 amp fuse for the VSC,VDIM circuit and then #22 the 30 amp VSC circuit...... as best as I could tell both looked good.
Nothing there so I moved on to the passenger side fuse box and checked out #17 a 10 amp VDIM and VSC circuit and this fuse checked out too.
Last I inspected for leakage around the intake and the MAF
So here I am back to square one and glad Lexus service hasn't called yet to schedule an appointment.
Why? .....I am still hopeful there is someone out there with something else to try and solve this.......??
Old Oct 9, 2013 | 11:15 AM
350stew's Avatar
350stew
Anyone have experience with these symptoms and codes that can share something I may be missing
Old Oct 9, 2013 | 05:32 PM
Gville350's Avatar
Gville350
Did you have the fuel pressure sensor recall performed? My service history on Lexus.com shows this :
BLA TIGHTEN FUEL PRESSURE SENSOR GASKET - IS/GS
Repair # 035716L
Old Oct 17, 2013 | 02:30 PM
350stew's Avatar
350stew
Thanks for the heads up have a list of six recalls to be done or.... campaigns they call them.
Hopefully the fuel pressure sensor "BLA" fixes my problem.
D2G
DLA
DLB
BLA
ALE
9LG
Old Oct 17, 2013 | 08:37 PM
Bichon's Avatar
Bichon
Why all the messing with things related to VDIM and VSC?
The Check VSC message and light come on ANY time the check engine light is on. That's because the car automatically disables traction control when the CEL is lit, not because there is anything wrong with it.
Old Oct 21, 2013 | 01:16 AM
350stew's Avatar
350stew
Thanks did not know this any thoughts on PO193 code = Fail Fuel Rail Pressure Sensor Circuit High Input???
Old Oct 23, 2013 | 04:57 PM
350stew's Avatar
350stew
D2G
DLA
DLB
BLA
ALE
9LG
Well got a call back from the dealer today to be informed the the fuel pressure sensor was faulty and they were going to do me a favor and not going to charge for labor. However the part was going to be $480......!!!
Thoughts
gxman1
GX - 1st Gen (2003-2009)
Jun 27, 2014 07:53 AM
turbo556
Sep 29, 2013 09:15 PM
L-tunedGS4
Oct 28, 2009 10:11 AM
HarrierRX300
RX - 1st Gen (1999-2003)
Apr 7, 2008 11:04 AM
sarge98
Feb 4, 2007 02:21 PM
