I have a question. Please help
Old Sep 2, 2013 | 06:49 PM
vietboy1st's Avatar
vietboy1st
Question I have a question. Please help
When i step on the gas hard to increase the speed, the RPM meter tended to stall at 5-7 for at least 2-4 seconds or i have to left my foot off the gas pedal until it can able move to the next gear on automatic.. Do you guys know what?
I installed the Takeda short ramp intake in it. Other than that everything is stock. Looking to buy the HKS hi-power exhaust and that will be it.. Please help me out. This is my first car i buy it with my own money.. Yes it is used lexus is250 2010 24350 mile now got it almost a month now...
Old Sep 2, 2013 | 07:36 PM
Allout's Avatar
Allout
Has it been doing that ever since you installed the intake? Did you connect the maf sensor that goes on the intake back or did you maybe drop or damage it when you were installing your intake?
Old Sep 9, 2013 | 05:01 PM
vietboy1st's Avatar
vietboy1st
No, i didn't drop it or damage it. When i removed the maf sensor, i installed it in the new takeda intake short ramp pile right away. Didn't move it outside or anything. Do you think i should buy a new maf sensor just in case?
Old Sep 9, 2013 | 06:34 PM
nbrhd's Avatar
nbrhd
is the 'check engine' light on?
Old Sep 16, 2013 | 06:26 PM
vietboy1st's Avatar
vietboy1st
no, car is perfectly fine if i drive normal. unless i want to accelerate hard on the highway, the rpm meter will stall for 2-3 seconds before it can go to the next gear on automatic mode..
Old Sep 16, 2013 | 06:57 PM
dong888's Avatar
dong888
if you are on "sport" mode, with hard stepping on gas, the car will always pick and stay in the higher RPM range, probably between 3-6.
Old Sep 23, 2013 | 05:15 PM
vietboy1st's Avatar
vietboy1st
no i was talking about driving normal mode. Not sport mode..
Old Sep 23, 2013 | 05:25 PM
laobo979's Avatar
laobo979
I bet your not use to the few second lag you get from the electronic throttle compare to the cable style.
Old Sep 24, 2013 | 09:30 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
post a video.....
Old Sep 24, 2013 | 12:57 PM
Gville350's Avatar
Gville350
Not sure about your 2IS, but mine downshifts like a champ in less than 1 second when mashed at any speed.
Perhaps a reset of the systems will force the vehcile to "re-learn" your driving habits.
Old Oct 7, 2013 | 05:29 PM
vietboy1st's Avatar
vietboy1st
Question
how can i reset it?
studzz12
IS - 1st Gen (2001-2005)
May 30, 2013 08:04 AM
08ChrIS250
Performance
15
Sep 20, 2010 10:01 AM
Bigwun07
Performance
Feb 26, 2008 07:17 AM
markgs4
Sep 27, 2005 09:08 PM
MrJohnTan
Oct 27, 2003 03:05 PM
