Custom intake using this...
Old Sep 16, 2010 | 10:16 AM
08ChrIS250's Avatar
08ChrIS250
Default Custom intake using this...
just wondering if anyone has made an intake with custom piping and this...
2006-2007 Lexus IS250 Mass Air Flow Sensor Adapter - Spectre - Chrome plated, Direct OE replacement
Part #: S718705
Mfr #: 8705
$29.78
Old Sep 16, 2010 | 11:49 AM
06isDriver's Avatar
06isDriver
I think I remember trying that out and the maf sensor adapter didnt actually fit. I eventually had to hand make my intake to place the maf sensor where I wanted it.
Besides, the whole thing is just a cheap piece of plastic.
Old Sep 16, 2010 | 11:55 AM
08ChrIS250's Avatar
08ChrIS250
did u just cut it out of the OEM intake pipe?
Old Sep 16, 2010 | 11:58 AM
06isDriver's Avatar
06isDriver
no, I used a donor cheapo intake from ebay. You could pick one up for about 30 bucks last time I looked. I cut the small square area of the maf sensor location out and then transplanted that onto some 3 inch aluminum tube.
Old Sep 16, 2010 | 12:59 PM
08ChrIS250's Avatar
08ChrIS250
Did it look like this by chance?
Old Sep 16, 2010 | 05:47 PM
06isDriver's Avatar
06isDriver
yes, they all look the same. Even those 300 dollar intakes are nothing but that.
Old Sep 17, 2010 | 06:20 AM
08ChrIS250's Avatar
08ChrIS250
ha yeah that is one thing i can agree with... like i said in my other thread before, it makes no sense to spend 300-400 on an intake that produces maybe 5hp. I just want to see if i can get a slight increase in MPG... i would assume a smooth pipe intake with performance filter will give me at least a couple mpgs.
My only concern with ordering a cheap ebay intake is the MAF sensor will not reach the port on the intake. im sure that the one pictured above is not the same as the one designed for the car... ebay stuff usually pictures different items than what is shipped.
i will be making frequent road trips the next few weeks out of state and need anything i can get to increase MPG... i'll have to give it a shot
Old Sep 17, 2010 | 07:32 AM
06isDriver's Avatar
06isDriver
oh it'll reach...the maf sensor wiring is very long. the thing to worry about is the stock vacuum hose not being long enough for the new intake. That does appear to be the exact intake you'll get btw.
Old Sep 17, 2010 | 07:58 AM
Kurtz's Avatar
Kurtz
Manufacturers would love if simple changes that cost them virtually nothing could bump their CAFE numbers.
If a smoother intake tube would provide a measurable MPG improvement it'd come like that from the factory.
(ditto for a filter change, unless you're talking about a filter so "open" it fails to filter properly... though even then I doubt there'd be an MPG improvement since the stock intake already flows more CFM than the engine can use)
Old Sep 17, 2010 | 08:54 AM
06isDriver's Avatar
06isDriver
or a filter so clogged that a new one restores the lost performance to begin with
Old Sep 18, 2010 | 09:42 PM
ilv1004s's Avatar
ilv1004s
so more like use the stock intake pipe use that bit and add a pod?
Old Sep 18, 2010 | 10:24 PM
Kurtz's Avatar
Kurtz
Do you mean stick a big cone filter on the end of the stock pipe?
All that'd do is insure you sucked in hot air, which isn't usually a goal of a performance modification.
A "bigger" filter is pointless since the stock one flows more air than the engine can use.
Old Sep 19, 2010 | 01:53 AM
ilv1004s's Avatar
ilv1004s
Ofcourse i was asking the op
wat the purpose of that extension is for
Old Sep 20, 2010 | 06:04 AM
08ChrIS250's Avatar
08ChrIS250
over the weekend i was able to get a better look at the intake on the IS... noticed it has a scoop that runs just behind the hood latch making the OEM system a CAI. only thing i wish it had more air flow from the grill to the intake inlet. it seems like there is only a very small slit that the air squeezes through.
The purpose of the MAF adapter i posted in the first post is to see I could run custom piping to a lower location in the engine compartment.... there really is not enough room to run it anywhere. The OEM setup is really the best location...
I noticed inside the OEM airbox is a secondary filter. I pulled that out (located just above the dropin filter and is attached to the airbox.
Old Sep 20, 2010 | 08:41 AM
Kurtz's Avatar
Kurtz
Now put it back in.
Dyno testing actually showed a 1 hp loss from removing that thing :P
