both ballast are bad
Old Aug 9, 2013 | 07:31 PM
blancois's Avatar
blancois
Default both ballast are bad
hey CL i need your help. both of my ballast are bad due to buying ddmtuning bulbs. now i need to replace them but dont know how. does anyone have a diy? should i go to a professional place, and do you have any idea of the cost?
Old Aug 9, 2013 | 08:35 PM
my1s250's Avatar
my1s250
go on ebay and buy the ballast take off the bumper and remove headlight and the ballast is under the headlight
Old Aug 16, 2013 | 07:18 PM
blancois's Avatar
blancois
^^^ thanks
Old Aug 16, 2013 | 07:34 PM
NickTomsyc's Avatar
NickTomsyc
What year is the car?
IFRC The 06-07 had the ballast as part of the headlight housing... as in you're not getting it off.
If thats the case I would suggest getting the "loaded" 2011+ headlight retrofits from Sewell... plug n' play
Old Aug 17, 2013 | 08:20 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
On 2006-2010 models the ballast bulb connector cannot fit past the AFS motor and so cannot be removed without disassembly. You can either bake the headlight and open it up to get the ballast out or remove the bulb connector on the ballast so get it past the AFS motor. There are videos on YouTube showing how to perform these tasks.
On 2011-13 models there is no AFS and so the ballast is easily replaced.
Either way you will need to remove the bumper to get the headlights out.
Jeff
Old Aug 17, 2013 | 03:01 PM
rog1206's Avatar
rog1206
Here's a vid that shows how to take apart the connector for the ballast:
Zmon
Aug 11, 2021 03:34 PM
jtork2
IS - 1st Gen (2001-2005)
Jul 13, 2013 09:24 PM
GFM2Fitty
Sep 12, 2010 02:23 AM
