False start problem. Need advice
Old Aug 3, 2013 | 11:37 PM
wculbert's Avatar
wculbert
Default False start problem. Need advice
My 2006 IS 350, which I've had since new, has recently been misfiring. That is, when you push the start button the engine turns over briefly, but does not start. Usually it starts on the second try, but sometimes takes up to 4 or 5. I have had it at the local dealer twice, and they are basically telling me to live with it. The first time I had it in they changed the plugs ( had never been changed- now at 85,000 miles) and did some other firing related things to the tune of $500! They commented on how they could tell that I had been using "good" gas. Then, when the problem continued, I took it back to them last week, and they said it was probably "bad" gas.
I called Lexus Consumer Care and they were of little help.
Anybody else out there have this problem, or suggestions on what to do? Thanks!
Old Aug 3, 2013 | 11:40 PM
Sffd103's Avatar
Sffd103
Fire Slayer
Just out of curiosity, have you ever changed the battery?
Old Aug 4, 2013 | 08:17 AM
jgr7's Avatar
jgr7
^^^^ +1 on the battery, my wifes RX started doing the same thing, changed the battery and all was well again.
Old Aug 4, 2013 | 11:48 AM
Gville350's Avatar
Gville350
Agreed, start with a new battery.
Off-topic, where in SC are you located?
Old Aug 5, 2013 | 10:26 AM
whitebeast's Avatar
whitebeast
+1 for battery check
Old Aug 5, 2013 | 10:52 AM
wculbert's Avatar
wculbert
Default Other ideas?
Thanks for replies, but the battery was replaced a year ago. Other ideas?
Old Aug 5, 2013 | 12:45 PM
whitebeast's Avatar
whitebeast
How many key do you have? Trying to start your car with second key (if you have)
some strange but why not try it. My friend has similar problem turn out the immobilizer being bad
Old Aug 5, 2013 | 04:10 PM
4TehNguyen's Avatar
4TehNguyen
get it load tested at autozone or whatever anyways to be sure
Old Aug 5, 2013 | 05:36 PM
Gville350's Avatar
Gville350
Test out the alternator and battery. Wouldn't be the first 1yr old battery in history being faulty.
Georgeonao
RX - 3rd Gen (2010-2015)
Nov 9, 2017 09:49 PM
Dan0327
Aug 26, 2017 04:16 PM
jdmada
Maintenance
Jan 31, 2010 03:56 PM
spxChrome
12
Dec 23, 2003 01:00 PM
