New car problem...
Old May 14, 2013 | 03:37 PM
Wojtasiak's Avatar
Wojtasiak
Default New car problem...
I just bought IS 250 AWD 2010 and I have noticed that right headlight is looking a lot higher then the left ( the driver side ) . I went to Lexus Deler to do the alignment and by the way check this light...And they told me that this is normal and the right headlight ( passenger side ) should be higher and the left side should be lower to not dazzle drivers coming from other direction.Is that true ?
Old May 14, 2013 | 03:46 PM
Tapangb's Avatar
Tapangb
Both my headlights are dead even when parked in front of my garage door. I've been told that the driver's side headlight is supposed to be slightly lower than the passenger side as to avoid blinding the driver in front of you. Doesn't seem to be the case on my car. Has your vehicle ever been in a front collision?
Old May 14, 2013 | 04:07 PM
lysis250's Avatar
lysis250
Mine are also pretty even, but the passengers side is just a tiny bit higher than my drivers side. I can only notice the difference when closely paying attention for a little bit.
Old May 14, 2013 | 04:15 PM
KINETICS's Avatar
KINETICS
if you park about 10 - 15 ft from a wall and cover each headlight at a time...you will see that they have sort of a pattern that makes the driver side lower than the passenger side to avoid blinding other oncoming drivers.
the pattern for each beam should look something like this
................._____________
__________l
laobo979's Avatar
laobo979
Park up againt a wall take a pick. Passenger side should be a little higher for the reason they say. But if its beaming to high then they will need to adjust it.
Old May 14, 2013 | 08:16 PM
Nikon's Avatar
Nikon
mine is lower on the driver side. i don't mind as i don't want to glare oncoming drivers.
Old May 14, 2013 | 10:46 PM
2genIS's Avatar
2genIS
same here.. driver side is lower then passenger...
Old May 17, 2013 | 03:08 AM
dk626's Avatar
dk626
driver side is suppose to be lower but you can adjust yourself with just a flathead screwdriver
Old May 17, 2013 | 11:38 AM
KINETICS's Avatar
KINETICS
Actually for non-HID AFS you need a philips' screw driver, or a 10mm socket wrench/ratchet
Hbhandal
Jun 13, 2019 09:59 PM
jhardy
Nov 4, 2016 12:13 PM
Shawnalk
Apr 21, 2010 10:46 AM
