Brand new led headlight dont work
Has anyone ran into an issue where only one headlight led works the other doesn't...probably a defective one? Just the led strip doesn't power up.
I figured id post it here since theres more people here then isf forum
sorry dumb question.. i just re read it. i would open the covers and look around the best you can to see if a plug came undone and if you dont see anything loose then send it back where you bought it from and ask for a replacement.
It's only driver side headlight. When you start the car the LED strip flashes on and then goes off immediately and does not come on under any light function (off/parking/low beams).
Harness looked okay with a quick check when we swapped them.
I had the same problem .. Gotta wire the other side
run a live wire on it from the headlights that works then wire it to the other headlights
I spliced the red wire as far as I remember for power
Yes there are 2 things u need to do, if u missing the harness of 1 of the headlight then u have to call Sewell to send you in my case i had to called local Lexus dealer to bought the part. 2nd u have to run another wires for power . U bought the stripped version right ? that should be it. If u already have the harness then just run another power wire that's all . Good luck
Adam350is
CL of Southern California
Nov 25, 2013 09:03 AM
