navigation conversion??
Old Feb 4, 2013 | 03:29 PM
H0LLYW00D's Avatar
H0LLYW00D
Default navigation conversion??
hey guys i know this may be a stupid question but i have a 2009 is250 and i have the stock head unit WITHOUT navigation i was wondering if i can get the navigation will it be a plug and play item or will i need to change the entire dash harness for me to accomplish this if so what is everything that i would need for me to do this conversion successfully thanks guys!!
Old Feb 4, 2013 | 03:36 PM
ISFHEMS's Avatar
ISFHEMS
Try this link, it should have all the info you need
https://www.clublexus.com/forums/is-...250-350-a.html
Old Feb 4, 2013 | 03:42 PM
NimaM's Avatar
NimaM
There are two options. FluAudio (the link above) and a much much cheaper unit from china.
https://www.clublexus.com/forums/is-...ufacturer.html
Old Feb 4, 2013 | 03:50 PM
ISFHEMS's Avatar
ISFHEMS
I know that there are A LOT of posts in the second link that NimaM put up, but it's definitely worth reading because some folks have had problems with the heater vents not fitting properly.
Good luck!
Old Feb 4, 2013 | 04:10 PM
H0LLYW00D's Avatar
H0LLYW00D
wow!! thanks everyone for the replies I'm gonna read over a few things and then let you guys know thanks again!!
Old Feb 4, 2013 | 04:34 PM
ISFHEMS's Avatar
ISFHEMS
Glad we can help!
This is another good link to check out!
https://www.clublexus.com/forums/is-...iy-thread.html
Lots and Lots of really great info from a great community!
Old Feb 5, 2013 | 11:21 AM
H0LLYW00D's Avatar
H0LLYW00D
Default thanks!!
IS350HEMS thanks man i just finished reading the write up and I'm going to start obtaining parts for this build stayed tuned CL!!
Old Feb 5, 2013 | 11:54 AM
ISFHEMS's Avatar
ISFHEMS
You are very welcome, looking forward to seeing the updates!
Old Feb 5, 2013 | 12:15 PM
B16da9's Avatar
B16da9
Just an FYI the none ML navifation unit does not play DVDs so if you're looking for that feature it might be best to go with one of the aftermarket units from FLyaudio or the much cheaper chineesse unit.
Old Feb 5, 2013 | 05:20 PM
NimaM's Avatar
NimaM
Good luck!
Yes, it seems like people are having fitment issues with 06-08 models which have a different center vent design and that cheaper nav unit is supposed to work with 09+ vents if I remember correctly.
Old Feb 6, 2013 | 02:33 PM
H0LLYW00D's Avatar
H0LLYW00D
if i go with a flyaudio design will i also need a new dash harness or will this unit plug directly with what i have??
Old Feb 6, 2013 | 02:50 PM
B16da9's Avatar
B16da9
plug and play.
Jrodis
Mar 24, 2015 08:49 AM
