speedometer not working properly
Old Nov 22, 2012 | 01:53 PM
bassamz's Avatar
bassamz
Exclamation speedometer not working properly
Hi, I have an issue with my speedometer not working properly. The issue appeared after I installed My2012 headlight from sewell. I did not replace the flasher relay coz I think everything is working right.
This is how my car starts now.
http://www.youtube.com/watch?feature...&v=cmWiN1hh0uE
Old Nov 22, 2012 | 05:28 PM
configt's Avatar
configt
Did you check it all out before you put the bumper cover back on? Install the relay, and make sure the large connections to the lights are connected completely. Sometimes they need a little shove.
Old Nov 23, 2012 | 02:29 AM
bassamz's Avatar
bassamz
all lights are working correctly. even the turn signal are working without the new relay. I wonder if the relay has something to do with this problem ?
Old Nov 23, 2012 | 04:00 PM
Jake's Avatar
Jake
Did you forget to plug back in your parking sensors?
Old Nov 23, 2012 | 04:02 PM
Jake's Avatar
Jake
The "AFS off" light will always blink, that's because the new headlights don't have the feature that helps you turn into the corners like the olds one do. You can open up your instrument cluster and put a piece of black tape over the light.
Old Nov 23, 2012 | 04:03 PM
Jake's Avatar
Jake
Sorry to post for the third time. It's all coming to be. You need to install the relay because if you don't then your turn signals will hyper-flash.
Old Nov 23, 2012 | 07:48 PM
bassamz's Avatar
bassamz
no worries man. I don't have the hyper flashing issue. I think all light are working just fine. I am gonna post a video on that. and about the parking sensor I have the front right sensor's cover broken i am going to replace it and see what happens then.
Old Nov 24, 2012 | 06:14 AM
bassamz's Avatar
bassamz
http://www.youtube.com/watch?v=iTuLG...ature=youtu.be
I posted a video showing the turn signal
Old Nov 24, 2012 | 08:46 AM
davyjordi's Avatar
davyjordi
sure the dash lights are fine, but are they hyper-flashing outside of the car, though?
Old Nov 24, 2012 | 10:07 AM
bassamz's Avatar
bassamz
I don't think that there will be any difference, but I will check them. And I also ordered a new flasher hope it will solve the problem.
Old Nov 24, 2012 | 10:17 AM
davyjordi's Avatar
davyjordi
sometimes there is, indeed, a difference. i don't know about the isx50, although the alfa romeo i had in high school while in europe a few years back showed the dash lights as normal but the exterior lights as hyper-flashing.
Old Nov 24, 2012 | 11:42 AM
bassamz's Avatar
bassamz
I checked it from the outside, everything is working properly. will wait for the new flasher relay to come in and install it and see what happens. It may take a while for the order to come since I am not in the US.
Old Nov 24, 2012 | 12:43 PM
Jake's Avatar
Jake
Just make sure you order the flasher for the 2011+ IS w/ the LED daytime headlights
Old Nov 24, 2012 | 12:49 PM
bassamz's Avatar
bassamz
I ordered this part number 81980-06020. I hope it is the right one.
Old Nov 24, 2012 | 05:56 PM
NimaM's Avatar
NimaM
I don't know, but may it has something to do with a region specific Lexus model not being compatible with the newer lights (just a thought)...
AMauriG
Feb 24, 2018 02:06 PM
BoostAddct
Jan 6, 2013 03:02 PM
acc
Aug 19, 2010 02:02 PM
Cochisecc
Nov 20, 2009 08:54 PM
lex2001
Jan 9, 2009 04:42 PM
