Aftermarket Soundsystem help
hey man, audio guru here. ive had probably 15 different setups in my is250. audiocontrol is the way to go. jl is expensive as is audison bit one and when it comes down to it they do the same job. lci6 or lci8 is ur best bet. i used a line out converter for my first install and i had similar problems with the sub hitting completely out of phase.
anyway i took it to the shop that did the install and they agreed to check it out properly, hook it up to another sub, check out the box and even hook it up to a audison bit one to see if any of these will sort the issue out. So hopefully in a weeks time i can get that done and figure this out. The guy at the shop doesnt think a processor will solve my problem. he thinks its a faulty sub. its all very confusing.
marvin5881
HS 250h Model (2010-2012)
23
May 11, 2026 07:15 PM
NotSuhShur
18
May 12, 2012 10:27 PM
Stealther
Apr 23, 2003 06:10 PM
