Headlight problem.
Old Mar 19, 2012 | 01:59 PM
Mancebof's Avatar
Mancebof
Default Headlight problem.
So i recently went down from aftermarket 6000k to 5000k. Ive always seemed to have had problems with my passenger side lowbeam light previously i had a very light flickering which lead me to change the bulbs. After i swapped the bulbs out i turned the lights on and they worked perfect i shut the car off and put everthing back in place. When i turned the car on to move it the passenger side light was out. I tried switching out the ballast for a spare i had, switchig the bulb, put the oem halogen and nothing lit so im guessing its something electrical with the oem wiring. any help?
Old Mar 19, 2012 | 03:47 PM
evogt500's Avatar
evogt500
Did you pnich any wires when putting the bulb in? Or is there a open wire (electricity short) that is touching the car body?
Old Mar 20, 2012 | 08:23 AM
Mancebof's Avatar
Mancebof
I think i did pinch the connector for the headlight because i cut small slats on the side of the housing cover to run the wires out i may have accidently closed the housing against the cable.
Its the cable which you connect the bulb to. I guess i have to go to the stealership and just turn in a arm and a leg. lol
GSbearcat
Apr 6, 2018 12:51 PM
JDMV8
IS F (2008-2014)
May 25, 2017 06:36 AM
Lexusfannn
May 28, 2016 11:49 PM
555555
Jan 28, 2013 01:34 PM
Tedstah
Aug 19, 2012 08:34 PM
