Bluetooth audio
Old Mar 5, 2012 | 06:34 PM
sthakor92's Avatar
sthakor92
Default Bluetooth audio
Hi i was wondering if it was possible to stream pandora from my phone (android htc evo) to play in the car via bluetooth? I have a 2011 250 without nav.
Old Mar 5, 2012 | 06:45 PM
BigWiLL345's Avatar
BigWiLL345
http://www.gromaudio.com/store/aux_a...e_adapter.html
im using this on my 06 250 with my EVO 4G
Old Mar 5, 2012 | 07:26 PM
yonick86's Avatar
yonick86
THANK YOU! been looking for a good solution for a while!
Old Mar 6, 2012 | 07:13 AM
Kurtz's Avatar
Kurtz
2010 and newer models don't need any adapter, they support music over A2DP from the factory
Old Mar 6, 2012 | 07:58 AM
smackman's Avatar
smackman
Default Help with Pandora 2011
I have a 2011 IS Convertible with Navigation. Please explain how to use Bluetooth to get Pandora to play from my Iphone 4S. My BT is Gray out.
Thanks
Old Mar 6, 2012 | 09:03 AM
yoegster's Avatar
yoegster
smackman, on an 11 plug your iphone playing pandora into USB and select USB on your display. If you use Bluetooth it will disable your ability to use the Bluetooth phone (take and receive calls). If for whatever reason you want to use Bluetooth, while the car isn't moving you need to go into Settings and turn on "Audio" in the Bluetooth settings.
Old Mar 6, 2012 | 03:35 PM
kl323's Avatar
kl323
You can connect your phone via BT allowing it to function as phone and media player at the same time.
Old Mar 6, 2012 | 03:37 PM
Fjaw's Avatar
Fjaw
just hit AUX a few times until it shows up as BT-A or BT-B (BlueTooth).
Old Mar 6, 2012 | 05:48 PM
toan414's Avatar
toan414
I had a 2011 IS 350 with no Nav. It had the bluetooth package. I also have the iPhone 4S. After I synced my phone to the car, whenever my phone plays music via pandora or my playlist, the little wireless bluetooth sync button pops up as an option when my phone is near the car. All I have to do is switch the audio source in the car over to AUX and the car starts playing my music. Very easy and I was able to keep the phone in my pocket or in the cup holder, no wires needed unless I want to charge my phone. That is a feature I really liked on my car and it was all automatic.
Old Mar 7, 2012 | 04:47 AM
yoegster's Avatar
yoegster
I believe if you are listening to BT Music and a call comes in the BT Phone does not function. I will try.
Old Mar 7, 2012 | 12:44 PM
sthakor92's Avatar
sthakor92
i tried this and it doesnt work, it just goes to Bt-a or cd
Old Mar 7, 2012 | 12:56 PM
sthakor92's Avatar
sthakor92
Just kidding, I paired my phone again and did the audio player too! it works
Old Mar 7, 2012 | 01:49 PM
smackman's Avatar
smackman
I got my Pandora to work over BT! I love this website. This 54 year old man needs all the help he can get with newer Technology! LOL
Old Mar 7, 2012 | 02:47 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Mine does.
iPhone 4S, 2011 without Nav.
Jeff
Old Mar 7, 2012 | 03:32 PM
toan414's Avatar
toan414
my iPhone 4s will ring and I press the answer button on the steering wheel to answer my phone. When I am done, the phone resumes the music. 2011 with no nav, so it should work.
