HELP DIY Reverse Lights
Old Feb 11, 2012 | 10:57 AM
TUNG's Avatar
TUNG
Default HELP DIY Reverse Lights
I just got my Cree reverse lights.. and it is half a inch bigger then stock and I can't place it in the socket. Is there anyone out there to help me.
Old Feb 11, 2012 | 11:20 AM
bob4256's Avatar
bob4256
It should just be plug and play, I didnt have any problems with mine. Maybe your trying to put them on backwards?
Old Feb 11, 2012 | 11:28 AM
TUNG's Avatar
TUNG
I got the stock out but it seems like the wire is tape up closely so there's barely any room for me to put in the longer length bulb. it is a plug and play but I was wondering did you guys have any trouble trying to put it in.
Sango's Avatar
Sango
Maybe you got the wrong type? It should fit in just like as is.
Do you have a picture?
Old Feb 11, 2012 | 11:47 AM
TUNG's Avatar
TUNG
Yes I have pictures and the Cree lights are longer then stocks by half a inch
Old Feb 11, 2012 | 12:04 PM
TUNG's Avatar
TUNG
Okay, here are the pictures.
Old Feb 11, 2012 | 12:11 PM
Sango's Avatar
Sango
Once I'l get my CREE's I'll take pictures.
The 1/2" longer is not the problem because my JLC 13-SMD reverse lights which is longer than 1/2" and fits fine.
Old Feb 11, 2012 | 12:13 PM
LexStylez's Avatar
LexStylez
I know what you mean. I bought mine from JLC and it fits. At first I thought it wouldn't fit because it was longer than stock but you just need to pull it back a little.
Old Feb 11, 2012 | 12:18 PM
Sango's Avatar
Sango
Yup, it can go quite longer because I did stick test by putting a chop stick and see how far in it went until I touched the housing and compared it to the light's lenght Plenty of room.
Old Feb 11, 2012 | 12:25 PM
TUNG's Avatar
TUNG
Yeah it would fit fine but I was having trouble putting it the housing
Old Feb 11, 2012 | 02:38 PM
Sango's Avatar
Sango
Maybe have to pull the harness back a little bit to have some room to get the reverse in there. I just got mine in, pics will come soon.
Old Feb 11, 2012 | 05:49 PM
TUNG's Avatar
TUNG
Okay thank you because I really want to get it done
Old Feb 12, 2012 | 08:23 AM
irishcharm's Avatar
irishcharm
i had the same problem. got the HUGE (double the OEM size) backup lights from ijdmtoy and had to use a panel pop to remove where the harness is clipped in. its just the harness thats stuck. free that and your golden.
Old Feb 12, 2012 | 09:01 AM
ms2619's Avatar
ms2619
who has brighter reverse lights? ijdmtoy or JLC and price difference? I'm ready to order some too
Old Feb 12, 2012 | 09:47 PM
brociouz's Avatar
brociouz
It might be easier to peel the trunk liner back so you can get more slack out of the harness.
