Inside trunk door
Old Jan 28, 2012 | 12:13 AM
Edzinsh's Avatar
Edzinsh
Post Inside trunk door
Hi,
Has anyone ever tried to widen backseat's tunnel? I understand that the size of inside trunk door and tunnel is ok for skiers, but as I am snowboarder then there is no normal way how to get snowboards inside the car - always need to use racks what I hate. Any ideas of adjustment of tunnel??
Edzinsh
Old Jan 28, 2012 | 12:25 AM
GiantsFan's Avatar
GiantsFan
Roof rack!
Old Jan 29, 2012 | 02:24 AM
Edzinsh's Avatar
Edzinsh
Nop, roof rack I really don't like on IS, unfortunately..
Old Jan 29, 2012 | 02:42 AM
Sffd103's Avatar
Sffd103
Fire Slayer
Originally Posted by GiantsFan
Roof rack!
You didn't hear the man Raj.
I've never seen any modification like this before. You'd have to cut your seat. You can probably remove the plastic portion but I don't think it'd make the hole wide enough.
Old Jan 29, 2012 | 08:43 AM
carlos3366's Avatar
carlos3366
Default how about a custom hitch rack? someboy in this forum
designed and built a great hidden hitch for the IS.
Old Jan 29, 2012 | 10:31 AM
GiantsFan's Avatar
GiantsFan
That's why I posted a pic of the rack
Not to mention you would probably have to cut into the metal that's BEHIND the seat!
Roof rack, even if disliked by the OP, is probably the best solution for his needs.
Old Jan 29, 2012 | 12:55 PM
brociouz's Avatar
brociouz
If you remove that plastic assembly that contains the ski-pass door, you might be able to get an extra inch of clearance. Other than that, you'd have to do so serious modding.
Another option, if you only have one passenger in the car and a roof rack is out of the question, is to put your snowboards in diagonally inside the cabin of your car.
MileHighF
Dec 5, 2016 10:49 AM
peewhy
Jul 24, 2012 09:34 AM
Annalyz
CL of Hawaii
Jun 13, 2009 04:13 PM
skyak
Jan 5, 2009 12:46 PM
AntLexus
Oct 12, 2007 03:21 PM
