Power Window Slam
Old Jan 2, 2012 | 01:33 AM
JohnLX300's Avatar
JohnLX300
Default Power Window Slam
After using a RX350 for the past two weeks while I had my piston rings replaced by lexus, I notice that the IS250 windows seem to slam on the way down and up. I don't know if slam is the correct word to use but the RX350 windows were smooth on the way up and down and they actual slowed down before hitting the bottom or the top when the window was opened and closed. Anyone else notice this with their windows. The Lexus service advisor said this was like this on all of the IS line and it was the most complained about issue. Thoughts??
Old Jan 2, 2012 | 02:04 AM
JDKane527's Avatar
JDKane527
CL Folding 25,000
For the RX, they added that feature in the design. My mom's '10 RX350 has it, and it's pretty nice, like a more intelligent design that doesn't put as much wear and tear on the window motor.
I've gotten used to the way the windows on the IS roll up and down though so it doesn't bother me personally.
Old Jan 2, 2012 | 02:18 AM
eggwoll's Avatar
eggwoll
Yeah mine slams too..... I believe the 09+ IS's have that feature too... I noticed it on the loaner 2011 IS I had
Old Jan 2, 2012 | 02:40 AM
Koolpep's Avatar
Koolpep
Hi John,
I can confirm that the Middle Eastern version of the IS does the same.
Just to confirm here is my voice recorders recording of the Back window opening and closing (while car is running) and the same for the front windows following it. Recorder was with me in the front.
Everything else in this car is supersmooth, the engine is barely there (especially the 3 litre V6 we have in the Middle East, 3GR-FE, 228 HP) and then the windows are a bit of a bummer ;o)
http://www.peppekus.de/Lexus/Back_Front.MP3
Cheers,
K
P.S.: What I really like about the windows is their speed. The car I had before this one was half the speed, was quite annoying if the window takes forever to go up and down, especially in our climate with up to 122 Fahrenheit in the summer and high humidity.
Old Jan 2, 2012 | 07:37 AM
stanjohn12's Avatar
stanjohn12
Originally Posted by Koolpep
Hi John,
Cheers,
K
I second coolpep on the gulf Spec IS 300 ,but I don't really have any problem with the THUD noise that comes with closing the window's. Anyways I hardly open my windows even in winter so as to not let dust get into my car
The only issue I have right now is slight squeaky noise coming from the driver side dashboard. I know it's fixable under warranty but I'm not getting the time to go to the dealer
Old Jan 2, 2012 | 08:17 AM
calvin2376's Avatar
calvin2376
Can someone tell me what's going on with the piston rings on the 2IS? I keep seeing posts about it. Is it a new recall or TSIB? Is it just a new fix for an older common issue? Is it limited to the 250 or 350?
Old Jan 2, 2012 | 10:26 AM
Kurtz's Avatar
Kurtz
Not sure how it fits with the rest of this thread, but since you ask...AFAIK it's the "new" fix for the carbon buildup issue on the 250 (doesn't apply to 350)
Old Jan 2, 2012 | 10:31 AM
VIS250P's Avatar
VIS250P
U mean the window fall down???? IT is the plastic tab under the window cuz break.. It cover on the TSB
Old Jan 2, 2012 | 12:14 PM
edgeucated's Avatar
edgeucated
Im currently driving an RX loaner too, and everything seems quieter on this car haha. The car starts up quieter and such
Old Jan 2, 2012 | 01:22 PM
dorkacho's Avatar
dorkacho
Yah, mine slams too, but personally I've always thought it was the way it's supposed to be ..
Old Jan 2, 2012 | 08:22 PM
JohnLX300's Avatar
JohnLX300
This is a new TSIB, its supposed to reduce the blow back and reduce the carbon build up on the intake valves. This is what the service advisor told me. I did experience a like every 2-3 months where my car would almost stall slowing down to a red light. That a a reduction in my average mpg. I was averaging around 28mpg mixed driving and it has been a steady decline to around 22mpg. Hope this works.
scamsel
IS F (2008-2014)
Jun 10, 2014 10:40 AM
sbaldwin77
Dec 4, 2013 08:36 PM
lok888
Sep 28, 2006 10:18 PM
gp1200x
RX - 1st Gen (1999-2003)
Aug 6, 2003 12:06 AM
strongsail
Apr 17, 2003 12:51 AM
