rotate screwup- any damage?
Aug 21, 2011 | 01:29 PM
I just had my tires rotated and they put the backs on front and fronts on back. I noticed a scraping noise when I turned. My question is when I get them put on correctly is there any damage I should look for? Tires, rims or wheel well?
Disappointed the missed staggard setup.
Aug 21, 2011 | 01:39 PM
Did the dealership do this? If it caused any damage, get them to pay for that kind of mistake.
Aug 21, 2011 | 02:14 PM
If its just the tires, then you should check the fender liner.
Dealership or not, you would have a good argument at having that place pay for the damages.
Aug 21, 2011 | 02:19 PM
My question is how did you not know they were staggered? You can tell by simply looking at the tires that they are different sizes...
Aug 21, 2011 | 02:58 PM
Thx. Yeah when I picked it up I was busy and didn't notice. Luckily I've only driven about 20 miles. It was a local tire chain.
Aug 21, 2011 | 03:01 PM
Aparently you just found out they're staggered? Why were you having them rotated?
Aug 21, 2011 | 03:21 PM
I knew the were staggard. I was expecting swap left front to right front etc non directional tires. Does anyone else rotate?
Aug 21, 2011 | 03:30 PM
Just had mine done last week, left to right too.
I would check the fender paint, cause mine cracked due to rubbing on tight turns..
Aug 21, 2011 | 03:52 PM
swapping left to right wouldn't make no difference in staggered wheels. should have left them alone.
Aug 21, 2011 | 03:56 PM
Quote:
Originally Posted by
Denver
Wrong.
Some people do this if they are running higher than normal camber numbers to get the most outta the tire. You have to remove the tires and swap them l to r
Aug 21, 2011 | 03:57 PM
Denver
Swapping left and right would counter or balance out the cupping effect for non-directional tires. Of course this would imply that the tire be taken out of wheel and to put it on the other wheel.
Directional tire, can't do that because the nature of the tread design.
Aug 21, 2011 | 05:49 PM
You can swap left to right on directional tires as well, you just keep them facing the correct direction.
The only time this doesn't work is if the tires have an inside/outside tread pattern, which is very rare.
Jeff
Aug 21, 2011 | 05:51 PM
Do the rear rims even fit over the is350 calipers? You prob melted the fender-liner a bit. Request them to replace it!
Aug 21, 2011 | 06:06 PM
Jeff Lange
Jeff
Oh yes that's true, but it's not really cost effective.
100degrees
Assuming OEM 18" or 17", it should be able to clear the calipers.
Helmar
Oct 22, 2009 08:34 AM
SNiiP3R
Wheels, Tires & Brakes Forum
Jul 29, 2009 12:32 PM
njmurvin
Sep 19, 2008 11:03 AM
koda
Dec 17, 2006 01:18 PM
lex430
Oct 27, 2001 05:34 AM
