CD Unit Not Functioning - Please Help
Old Jul 23, 2011 | 09:27 AM
thomjoss's Avatar
thomjoss
Default CD Unit Not Functioning - Please Help
I just bought a 2006 250 and the CD changer does not work. This is a non nav non levinson radio. None of the buttons on the CD changer work. Only the volume and tune **** work. I can push all of the other buttons on the changer unit and they don't do anything. The only way to change the audio mode is to use the mode button on the steering wheel and it only allows switching from am to fm.
Does anybody know whats wrong? Does anyone know who makes the cd changer so I can send it in for repairs?
Old Jul 23, 2011 | 11:14 AM
twenty's Avatar
twenty
Is there an error message on the screen or any lights flashing where the CD is inserted?
Old Jul 23, 2011 | 01:57 PM
Gville350's Avatar
Gville350
So it was like that when you purchased the car? Hmmmm, I'd start by disconnecting the battery for 10-15 minutes and see if that resets anything.
Old Jul 23, 2011 | 09:20 PM
thomjoss's Avatar
thomjoss
There are no error messages or flashing lights. Everything else with the radio functions properly. The PO told me it has not worked for a while. I will try to reset, but my plan is to pull it out of the dash and make sure all the wire plugs in the back are tight. I would like to send it for repair while I have it out, but I have no idea who made it.
Old Jul 24, 2011 | 11:28 AM
iceache925's Avatar
iceache925
Are there cds in the drive? If so, are they burnt cps, cd-r? or cd+r? The reason I ask if I had a problem a couple years ago when I had a 2007 IS250 and it sounds very similar to what happened to me. I took it to the dealer (still under warranty at the time) and they swapped our the cd player then told me to not user burnt cds. I told them B.S. because the car manual says you can use them in the cd player. I know this doesn't answer your question, I was just wondering if it had home made cds in the player.
Old Jul 24, 2011 | 02:19 PM
JoshIS408's Avatar
JoshIS408
- - G T V I P - -
Go to the passanger side and look under the console. There should be a fuse box under there. Pull out the Audio fuse should be called AUDIO or RADIO i forgot. Turn the car on then off. Put the audio fuse back in and start the car again. That should reset the whole cd changer. Let me know if it works
Old Jul 24, 2011 | 02:39 PM
allst4r's Avatar
allst4r
yes try that and remove all the old cds. and put in store bought cd that you have.... this happen to my old honda accord.. 2002... for some reason it stop responding to my burnt cd.but will play store bought cds.
Old Jul 25, 2011 | 02:21 AM
GilIS250's Avatar
GilIS250
Hmm... I have a similar issue, but it happens with my AUX function. I press it and nothing happens... I am just going to take it back to the dealership when I get back to the states ...
Old Jul 25, 2011 | 08:14 AM
Sango's Avatar
Sango
This would be a case of one of the two lasers has failed - the one in question would be the one which is able to read recorable media. The other laser, is the one which is able to read stamped/store cds.
Old Jul 26, 2011 | 10:01 AM
thomjoss's Avatar
thomjoss
I tried the fuse and it didnt have any affect on it. It looks like I am going to have to pull it and either have it repaired or buy one on ebay. Thanks for the help.
TCSteidel
IS - 1st Gen (2001-2005)
Jun 27, 2017 05:34 PM
hounddogs
May 1, 2013 03:37 PM
2JZGTTELEX
Mar 20, 2011 01:36 PM
saif9171
Mar 23, 2007 11:51 AM
MikeM
Aug 13, 2002 10:48 AM
