2007 is250...nav unit is dead. Quick question..
The touch screen still works you just have to assume it is on it was home page of the navi screen and use the manual to guide you through. Hop that helps.
I've read this being done by someone else with a transmission (non-Lexus tho). The person kept reporting that there was intermittent issues, but the dealer didn't fix under warranty. Of course, warranty endded and the transmission died. But the person got it replaced anyways because issues signaling it may die happened before warranty.
NAVI Commands
Command Alternate Commands with same function
Current position Current Location
Map
Cancel
Zoom In
Zoom Out
Right Map Zoom In
Right Map Zoom Out
North Up Change to north up
Heading Up Change to heading up
Map direction Change to map direction
Right map north up
Right map heading up
Right map direction
Dual map Change to dual map
Single map Change to single map
Mark this point Mark
Home Go Home
Repeat Guidance Repeat voice, Repeat
Louder
Softer
Arrow guidance Arrow guide, Change to arrow guidance, Change to arrow guide
Turn list guidance Turn list guide, Change to turn list guidance, Change to turn list guide
Entire Route map Entire route, route overview
Delete next destination Cancel next destination
Delete final destination Cancel final destination
Delete all destinations Cancel all destinations
Suspend guidance Stop guidance
Resume guidance Start guidance
Compass mode Change to compass mode
Lane guidance Change to lane guidance, Guidance screen on freeway
AUDIO Commands
Radio
AM AM Radio
FM FM Radio
FM1
FM2
CD
DVD
CD Changer
DVD Changer
Cassette
Tape
Audio Audio on, Audio off
Seek up
Seek down
Type up
Type down
Fast forward
Rewind
Reverse Program
Next track
Previous track
Skip backward
Play
Track up Next track
Track down Previous track
Disc up Next disc
Disc down Previous disc
Climate Commands
Automatic Air Conditioning Automatic Air Conditioning On, Automatic Air Conditioning Off
Raise Temperature Warmer
Lower Temperature Cooler
65 Degrees Temperature 65 Degrees
82 Degrees Temperature 82 Degrees
83 Degrees Temperature 83 Degrees
84 Degrees Temperature 84 Degrees
85 Degrees Temperature 85 Degrees
Help Commands
Help Command help, Command list
The auto button isnt working. Everything above the radio is dead....As for the voice commands, you got me all excited, but nothing. The radio control buttons on the left side of the steering wheel work, but the voice command button on the right does nothing.
2008 IS250 w/ 250K miles
Last week I go to turn on the car and the NAV screen develops horizontal lines during bootup then it fades to a white screen and then dead/black. Hasn't worked since then.
All buttons above the clock won't work. I checked all fuses, all good. Took it to a local mechanic and they tested the electrical, voltage and ground is going into the unit. They advised to replace the unit.
I took the unit completely apart and couldn't find any burnt capacitors or ICs on the electrical boards.
I also tried installing a new Digitizer screen but no dice.***don't waste your time doing this unless the NAV screen is on but not responsive to the touch, this is when you replace the Digitizer***
Going to take the NAV apart again and pop the boards into the oven and see if it fixes it (sometimes this trick works as the heat reseats the solder points).
My last ditch effort is to pick up a used unit from my local junk yard
If I can't find one them I guess I'll have to buy an after market one, not a fan of those since they tend to have low quality audio and I hate those crappy microphones and GPS antenna, not to mention installing an aftermarket camera when the car already has one.
PS: my local mechanic was able to turn the A/C on for me (don't know how tho), but it shut off again when I took it out. I'll be going back to ask them to turn it back on and this time I'll watch and see how tf they did it, I'm guessing by jumping a pin from one of the connectors.
Lexus first screws us over with the carbon buildup on the piston heads, and now this... so done with this brand, they're useless.
