REQUEST DIY Differential Removal
Old Jun 23, 2011 | 07:48 PM
HtownImprt's Avatar
HtownImprt
Default REQUEST DIY Differential Removal
well my differential on my AWD just crapped out, dunno what the cause was, could be staggered wheels, slammage, or bad luck, just unbolted the driveshaft hoping it was minor, ending up pulling out a large chunk out of the differential
it came loose while driving and all the fluid poured out and the rear locked up, if anyone have any idea what the part is and if it can be replaced/rebuildable or do i need a new diff that would be greatly appreciated, I know I need to drop the differential before knowing for sure what all needs to be replaced inside
heres some pictures
thanks all
Old Jun 23, 2011 | 07:55 PM
MyIS350G's Avatar
MyIS350G
wow sorry to see that bro. hope someone can help you with this
Old Jun 24, 2011 | 05:28 AM
B16da9's Avatar
B16da9
Your diff is toast, you have one of two options.
1. buy the internals to rebuild your current diff. (This is the expensive route)
2. buy a used diff and slap it on (The most cost effective route specially if you do the work yourself)
Now take it that you will still need to inspect the car to check if you have something causing this issue.
I would start by the drive shaft check to see if it's bent or damaged in any way.
Old Jun 24, 2011 | 06:12 AM
Damaster32's Avatar
Damaster32
yea i whole go find a whole new diff, from like to junk yard or something.
Old Jun 24, 2011 | 06:28 AM
HtownImprt's Avatar
HtownImprt
would the rear differential on the AWD be the same as the RWD? reason i'm asking is the AWD seems to be hard to find at the junkyard
Old Jun 24, 2011 | 06:29 AM
whitebeast's Avatar
whitebeast
good luck with finding used one and fix it.
Old Jun 24, 2011 | 06:40 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Might want to find out of the 3rd gen GS AWD differential is the same as the IS. Would increase your chances of finding the part
Old Jun 24, 2011 | 06:50 AM
HtownImprt's Avatar
HtownImprt
^^3GS AWD is just as rare to find at the junkyard
Old Jun 24, 2011 | 06:59 AM
Kurtz's Avatar
Kurtz
My vote would be staggered wheels... but you might want to find out why, or it'll just happen again to the next one
Old Jun 24, 2011 | 07:31 AM
Mv350's Avatar
Mv350
im with kurtz on this one
Old Jun 24, 2011 | 09:33 AM
HtownImprt's Avatar
HtownImprt
the car is back stock everything, so anyone know an easy way to remove the rear axles? or do i have to unbolt all the control arms?
Old Jun 24, 2011 | 09:57 AM
B16da9's Avatar
B16da9
The back axels should have between 6-8 12mm or 14mm bolts holding it to the diff. Just unbolt those and leave the axels on the car.
Old Jun 24, 2011 | 11:19 AM
HtownImprt's Avatar
HtownImprt
^^^ doesnt have bolts holding it into the diff, looks like it needs to be pry'd off like the fronts
Old Jun 24, 2011 | 12:07 PM
cloo7's Avatar
cloo7
what a nasty injury... goodluck on ur repair
Old Jun 24, 2011 | 12:51 PM
jnguyen87's Avatar
jnguyen87
is your stagger setup within 1" Overall Diameter of each other. I remember when i switched tires for a bit and i believe they werent withing the 1" OD because i could feel this weird vibration. I had a feeling it was mess up my AWD so i switched back to the old tire setup and then the vibration went away.
