REQUEST DIY Differential Removal
Old Jun 24, 2011 | 03:06 PM
Sffd103's Avatar
Sffd103
Fire Slayer
Sorry for your damage!
Old Jun 24, 2011 | 03:13 PM
KillaIS250's Avatar
KillaIS250
Damn first i ever heard of that happening on an IS. Try and find a used one from a junkyard or something though, if your doing labor yourself, it will be much more cost effective.
Old Jun 24, 2011 | 03:47 PM
HtownImprt's Avatar
HtownImprt
I've tried to stay within the diameter on my old setup but got a set of 19" G35 Rays, the two rear tires were different profiles, 35 and 40, didn't know how i missed that, but thats over an inch difference, could it be the cause?
Old Jun 24, 2011 | 05:05 PM
laobo979's Avatar
laobo979
Could be cant run 19s with 40 series it threw it way off. But here a link to a salvage awd hit them up
http://cgi.ebay.com/ebaymotors/06-07...#ht_1013wt_722
Old Jun 24, 2011 | 06:30 PM
HtownImprt's Avatar
HtownImprt
^^^already did thanks, $350 isnt a bad deal, was hoping the damage wasn't so bad, was planning on keeping the car but I guess it wasn't meant to be....
well i just removed the Differential, that thing looks like a mess on the inside, definitely wasn't repairable
Old Jun 25, 2011 | 09:54 AM
HaveBlue's Avatar
HaveBlue
Wow busted pinion. Make sure the replacement has the same gear ratio. 250s and 350s might not be the same.
Old Jun 27, 2011 | 12:48 PM
jnguyen87's Avatar
jnguyen87
Im almost postive thats what happened. When i was running experimental tire sizes, the vibrations just felt un-natural. So i knew i had to change back to the usual sizes right away. Fortunately nothing happened to my differential, as far as i know. I know i ran those experimental tire sizes longer then i should have too, but so far its ok.
Old Jun 27, 2011 | 03:40 PM
B16da9's Avatar
B16da9
^^^ doesnt have bolts holding it into the diff, looks like it needs to be pry'd off like the fronts
You are correct, I'm so used to how most RWD vehicles use bolts. Those pop out like on a Honda.
Old Jun 27, 2011 | 04:09 PM
FutureITR's Avatar
FutureITR
It's most likely your staggered wheels causing the problem.
alain173
Dec 6, 2016 05:44 AM
cdew002
GX - 1st Gen (2003-2009)
Jan 19, 2015 09:00 AM
bklynchris
Sep 20, 2011 12:19 PM
JeffTsai
Mar 23, 2011 08:18 AM
Sup2jzgte
Mar 31, 2010 11:53 AM
