Costco Battery Question
My Battery give up at me last night.. i been looking around people said that Costco battery are pretty good... but some also said the positive terminal of the battery is smaller than the oem one so the connections will be bad.. So is this true?
I did some research a while ago. Kirkland batteries have one of the highest Cold Cranking Amps on the market.
http://www.carsdirect.com/car-mainte...ws-and-ratings
WTH -_- took me like 20 min to take off that thing that that's holding the (+) then i put on the Costco battery i found out there was more then half an inch higher so i can't fit it....
Should I replace my battery when it's still showing good? I've about 120k on it so... Also, will your car feel weird when the battery is about to go bad? I'm a bit concern since so many of you guys have already replaced them.
I honestly don't mind buying one from lexus for 130 since it's the only battery i have that lasted that long. What do you guys think?
