Key Unlocks/locks Door But Won't Start Car! Help!
Old 02-24-17, 03:57 PM
  #46
karlkani
karlkani's Avatar
Default lexus immobiliser malfunction
Originally Posted by andyroo
Hey guys,
I've had my '06 is350 for 4 years now and have never encountered this problem. My car key unlocks/locks the door fine, interior lights and headlights/breaklights are working fine, but my key won't start the car. When I press the start/stop button, it doesn't go into accessory mode and absolutely nothing happens. I recently changed the battery on my key and I'm guessing that has something to do with it. This is really frustrating because I am sure it's not a battery problem because everything is working fine except my car is rejecting my key somehow(?) Please, if anyone could help I would greatly appreciate it.
I've been googling and googling about my problem, and the only relative results I got were all about engine immobilizing.
It seems that the car is not reading the key and I have to reset the immobilizer(?) Does anyone have a step-by-step process to do this or does the engine immobilizer have nothing to do with my problem??
-Andrew
Hey good day, did you get this problem solved and what was the fix? Im having a similar issue and need your assistance.
Thanks in advance.
-Kharl
Old 01-29-18, 10:11 AM
  #47
AR2
AR2's Avatar
Thanks in advance.
-Kharl
Hello, i was experience the same problem with my car 2 days ago , and today we could fix it and the problem was related with the ¨POWER SOURCE SUPPLY CONTROL MODULE COMPUTER ¨ that is located in front of the passenger seat. i hope this info can help if someone got this annoying problem. have a nice day guys.
GrizzlyMan (03-21-21)
Old 01-29-18, 10:25 AM
  #48
Htony
Htony's Avatar
Originally Posted by Dexterr
From what you described, sounds like your main ECU is dead.
I'd try another genuine brand name battery in the key fob. There are fake counterfeit batteries in the market.
If you have power trunk tried to open it too?
Old 12-31-20, 11:11 AM
  #49
jxwuts
jxwuts's Avatar
I feel like I need to double check on ruling on keys--- if a key can unlock and lock doors, that means the central receiver of the car has recieved the correct code right? Therefor the key has no problem, no need to question about second key? How can a key physically wireless unlock the door, and another part of it fail to start the engine? If the signal goes through the car antenna sensors into the main encryption control system, and correctly unlocked the door, then how in the world can the key itself have an issue?
Old 01-02-21, 06:57 PM
  #50
KH818
KH818's Avatar
I have this same problem did anyone figure this out??
Old 03-21-21, 10:52 AM
  #51
GrizzlyMan
GrizzlyMan's Avatar
Are you serious?
Another one!
Old 03-21-21, 01:37 PM
  #52
bkgthe1st
bkgthe1st's Avatar
If you look up a few posts he did explain that the dealership found that the Chassis Ground was corroded. The negative battery terminal has a cable that runs directly down next to the battery where it grounds to the chassis. That's what connects every piece of electronics in the car to the negative battery post. It just needed to be cleaned and reconnected.
Old 09-16-21, 12:42 PM
  #53
washang1
washang1's Avatar
Default Same
I am having the same exact problem with my 06 Lexus gs430.
silkx3
12-04-16 02:35 PM
EJC
06-27-16 09:58 PM
Sello
IS F (2008-2014)
09-13-13 04:20 AM
99GSoc06
10-05-11 07:30 AM
Bengalfang
10-27-06 11:15 AM
Quick Reply: Key Unlocks/locks Door But Won't Start Car! Help!
