Question About Headlights...
Old Oct 18, 2010 | 03:59 PM
ApokC's Avatar
ApokC
Default Question About Headlights...
I tried search but could not find the answer...
My left low beam just went out, and I want Xenon Halogens.
Stock has HID's right? Do i need anything to switch between an HID to a Halogen?
I was going for 8k lowbeams, 6k fogs, and idunno bout my DRL's yet
Thanks!
Old Oct 18, 2010 | 05:02 PM
brociouz's Avatar
brociouz
Come again? Do you have HIDs or halogens right now? It sounds like you want to switch from OEM HIDs to halogens, which makes absolutely no sense.
Old Oct 18, 2010 | 05:59 PM
projectdna's Avatar
projectdna
what you need to do is find out if your low beams are halogens OR HID's.
replacement is as simple as swapping bulbs - given that they are the same lighting system type (i.e. halogen, HID).
also...
Originally Posted by ApokC
I was going for 8000k lowbeams, 6000k fogs, and idunno bout my DRL's yet
fixed.
Old Oct 18, 2010 | 06:20 PM
tigabalm's Avatar
tigabalm
Okay, a bit of clarification:
HID - high intensity discharge aka xenon
Halogen - standard lighting, yellowish
If you are standard halogens, then you can either get higher color temp halogen bulbs, from luminics, sylannia, etc, but those wont be HID, just a bit "bluer/whiter" http://www.luminicsbulbs.com/hyper_white.php
or a HID kit, which would include a ballast, wiring and HID conversion bulbs.
http://www.kbcarstuff.com/HID-Kits-s/216.htm
or if you got some extra cash lying around you can upgrade to OEM HID headlights
http://is.sewellparts.com/accessorie...-2008-133.html (use CL login to get extra discounts)
If you have HID lights, then you just to need to get replacement HID bulbs, D2s (correct me if I'm wrong).
hope this helps
Old Oct 19, 2010 | 12:11 AM
Frosty250's Avatar
Frosty250
hope this helps
HID bulb is D4S
Old Oct 19, 2010 | 12:24 AM
tigabalm's Avatar
tigabalm
Right, my old Audi was D2S.
Thanks for clearing that up.
Old Oct 19, 2010 | 06:12 AM
ApokC's Avatar
ApokC
Ok so ya Im retarded, I want HID's haha
Everyone tells my I have HID's... so I just need to get a different bulb?
Also... how do I tell what my foglights are? They're not really yellow. Ill post a pic
Old Oct 19, 2010 | 06:19 AM
ApokC's Avatar
ApokC
So ya, picture made my lights more blue, but they are a bright pure white and they hum...
Its a stock 2006
Old Oct 19, 2010 | 06:26 AM
IXI187IXI's Avatar
IXI187IXI
look halogen to me, both headlights and fogs. if you want hids then you need to get a kit because you will need a hid ballast for each bulb.
Old Oct 19, 2010 | 06:32 AM
Kurtz's Avatar
Kurtz
Your car is an 06 right? that one is really easy.
Do you have memory seats?
If so you have factory HIDs.
If not, you don't.
Old Oct 19, 2010 | 06:51 AM
ApokC's Avatar
ApokC
Ya I have the 3 setting memory seats w/ telescopic wheel
So I have HID's ?
Even the fogs?
Old Oct 19, 2010 | 07:39 AM
Kurtz's Avatar
Kurtz
So I have HID's ?
Even the fogs?
No, just the headlights are HIDs. There's no such thing as factory HID fogs on US models. (I think Japanese models could get factory HID fogs but they're an insane amount of money to import, like a couple of grand just for fog lights)
(the reason it's easy to tell for you is on 06 models HIDs only came on the sport and luxury packages, which are also the only two ways to get memory seats... on 07+ models however HIDs were also available as a stand-alone option)
Old Oct 19, 2010 | 02:16 PM
netsrac's Avatar
netsrac
Well I was on Ebay today and found exactly what you are looking for.
Here is a link to different options. There are a lot of different sellers, just go with the one you are comfortable with.
Our lights are D4S model
Different colors are;
4300K Yellowish OEM - 3200lm - 3k hrs
6000K Ultra White - 3000lm - 3k hrs
8000K Brilliant Blue - 2500lm - 3k hrs
10000k Violet - 2300lm - 2700 hrs
But don't be fooled by higher number, the 10000K actually has the lowest Brightness/Lumens and shortest lifespan
Old Oct 19, 2010 | 02:52 PM
projectdna's Avatar
projectdna
Here is a -ebay link snip- to different options. There are a lot of different sellers, just go with the one you are comfortable with.
those lifespan ratings are a general representation of all (read: high- and low-quality) D4S bulbs, though most inferior-quality bulbs will not last anywhere near those lifespan ratings.
if you're looking for high-quality D4S bulbs, consider the GARAX brand:
https://www.clublexus.com/forums/5697400-post15.html
Old Oct 19, 2010 | 04:34 PM
ApokC's Avatar
ApokC
I was thinking Xenon HID's... what do you guys all have?
And also, should I just get a new Halogen Fog bulb or replace the fog housing to an HID setup?
Cuz I want the 8k (Light blue) lowbeams and 10k (dark blue) fogs
