New drl
Old Oct 4, 2010 | 06:08 PM
jlee403's Avatar
jlee403
Default New drl
yes i used the search tool, i just couldnt find it. please dont chew me out >.>
okay. so i ordered theses drl's http://www.v-leds.com/Interior-LED/G...04828-1-2.html
and i just got them today.
i have absolutely no idea how to install them. nor do i know whether or not theyll actually work.. lol guess and check? =/
okay so if someone could give me a very descriptive set of instructions on how to install these drls that would be great. pictures are nice too (:
Old Oct 4, 2010 | 06:12 PM
ScKcBc's Avatar
ScKcBc
those arent drl's, they are the parking lights. Pop your hood, remove the front engine cover and look for the cap on the back of the headlight where your brights are. Remove the cap, remove the bulbs and install. You need the SMT kit with the relay if you want to get the DRL's. Its like $100
Old Oct 4, 2010 | 06:18 PM
Kurtz's Avatar
Kurtz
Note too that if you did put LEDs in place of the actual DRLs you'd no longer have functional high-beams.
Old Oct 4, 2010 | 06:22 PM
mahcah's Avatar
mahcah
Yeah I just did mines. The 28 leds are pretty bright! I love them.
Old Oct 4, 2010 | 06:43 PM
jlee403's Avatar
jlee403
wait then what do i need to order for drl's?
i want white drls.. if someone would be so nice and actually send me a link for everything i need to have white drls... that would be pretty amazing
Old Oct 4, 2010 | 08:41 PM
svntwosix's Avatar
svntwosix
Hey mahcah, you sent me a blank pm. I assume you got it to working order. Post pics when you can .
Old Oct 4, 2010 | 10:42 PM
kingmich's Avatar
kingmich
Default Drl
Hello Lexus Family - I too have just begun my search for LED or HID. I've read so many posts, and I'm still left with a sinking feeling in my gut, "which ones".
Here is what I have found so far for the DIY, however I have not found the bulb yet-
DIY LED DRL and PARKING LIGHTS
https://www.clublexus.com/forums/is-...t-and-drl.html
https://www.clublexus.com/forums/is-...ng-lights.html
My 06 is250 is Not HID equipped.
I understand that the DRL is also the High Beam, and if I change the existing bulb to a led, I will lose my high beams. I am okay with that, as I drive mostly in the city. However, I also see the parking bulb, do I change both to attain that beautiful 80%White/ 20% Blue Glow ?
I've read that a relay or module is needed to avoid a flicker issue, but I don't know if this all comes together in a kit.
Old Oct 7, 2010 | 02:15 AM
phat167's Avatar
phat167
you can change both your drls and parking bulbs if you want. parking light turns on when you turn on headlights so if you change your parking lights you would have the white led parking lights on with your yellow headlights.
If you change your 9005 drl to led you do not need to change the parking lights to match. Parking lights does not turn on unless you tell it to, unless you like to drive with your parking lights on.
i used
http://www.v-leds.com/Interior-LED/G...38587-1-2.html
for my parking lights and
http://www.v-leds.com/Exterior-LED/D...79223-1-2.html
for drls on sale for 29.99 discontinued or you can get the newer ones for more
http://www.v-leds.com/Exterior-LED/D...52845-1-2.html
for the 68 led drl i got 2 modules to avoid flickering.. didnt really need relay harness
http://www.v-leds.com/Exterior-LED/D...97704-1-2.html
for the 28smt it is recommended to use the module and the harness if you want full power and no flickering , but you dont need to
http://www.v-leds.com/Exterior-LED/D...97704-1-3.html
http://www.v-leds.com/Exterior-HID-F...-p6162160.html
nated0323
Oct 24, 2015 10:21 AM
roumieh200
Sep 16, 2014 10:31 AM
TUNG
Mar 21, 2012 09:17 AM
jlee403
Feb 3, 2011 01:08 PM
OPTiK
Jan 2, 2011 10:01 AM
